200+ woodworking book reviews
270 degree Euro hinge
Bob Sobieck
>Has anyone used Profesional Hardware and Supply? I am looking at their 270 degree hinge. This is the only hinge I can find that is Euro style, all the other types of 270 degree show a lot of hardware on the outside. I could live with that but thought this may be better.
Any plus or minus regarding the product shown in the link below?
http://www.profhdwr.com/75270.htm
Thanks in advance.
Bob in Green Bay, WI
Re: 270 degree Euro hinge
Looks good to me
>I have not used this type of hinge, but it appears that the chrome you see on the edge of the door will only be about 35mm high, which is smaller than most conventional 270° hinges. It will be chrome, though -- no brass plate or other finishes available.
If you want something less obtrusive than this, you could get tricky with offset pivot hinges, and only have to look at small brass knuckles top and bottom. Of course, they will require a bit more work to layout and install correctly.
Ellis Walentine, Host
