A55 Smoothing Plane
Age / grit ratio . . .
SteveM
>It occures to me lately that, in my youth, I did'nt even KNOW sandpaper went any higher than 100. " Good enough, get it done. ". Now, polishing rusty plane bodies & saws and seeking that perfect, glassy finnish on wood, the grits I'm going to get higher and higher. Starting to wonder if theres a relationship between my age and the grit number. That'd be interesting. Stephen Hawking move over, I got it all figured out!
Re: Age / grit ratio . . .
OK, so how old / grit are you up to
Keith Newton
>If you are up to 120 grit, and you are about 35, that would be about right.
I am up to 320 grit, and the going gets slow.
Hmmm is abrasiveness related to age . . .
Lee Schierer - McKean, PA
>When I first read your post title I thought you were going to relate how abrasiveness is age related. I've certainly met some abrasive people, but didn't realize it might be age related. Hmmmmm :)
Lee
47 / 220. Hmmmmm, sounds right ?
SteveM
>At least its not weight right ?
Re: Hmmm is abrasiveness related to age . . .
Kneale Brownson in sunny N. MI
>I'm sure I've become somewhat less abrasive as my age climbed to 67. I have some crocus and emery cloth, but it never sees wood. I must be a sandpaper laggard as 220 is about as fine a grit as I use.
