O T Cracking Brazil nuts
Paul Waddle
>I was having a difficult time cracking and getting the kernel out of Brazil nuts. I had an epiphany and put three in the microwave for 20seconds-wha la,sure makes it easier to get the kernel out. Now some of you scientic types could run with this. I'm sure walnuts,hickory nuts,hazel nuts...etal would need a somewhat differnt setting/per nuts. Hi Mark,wifee says I have too lmuch time on my hands! pw
Re: O T Cracking Brazil nuts
Robert Henderson
>I gotta agree with your wife.
What's wrong with a hammer?
It always worked for me.
'Course, gettin' all thouse little shards of shell out of the nutmeat dust is a pain
how about black walnut
JohnKJordan in East TN
>Any ideas for black walnut? They are hard nuts to crack. I've had good luck nibbling at the shell with wire cutters but that takes a lot of time. A hammer wastes a lot.
I do smash them flat with a brick for the chickens. They seem to be able to pick out every tiny bit of meat and don't care if it's pulped. I just have to be careful one doesn't stick her head under the descending brick or we'll be having chicken for supper.
Re: how about black walnut
Jerry Nicholson
>When I was a kid I used the greasy old vice in my granddads shop to crack the black walnuts. Good stuff but I probably ingested a little grease and dirt along with the walnut meat. I tried cracking a coconut with a vice in my shop one time - bad idea! The coconut went all to pieces and dumped coconut juice all over the place.
Jerry
Same here
Lee Schierer - McKean, PA
>We used to do the same thing at my grandfathers shop. His vise wasn't greasy but it sure was strong. You could control the damage much better than with a hammer and the nuts didn't go shooting off across the room into the coal bin or under the work bench because you didn't hit them square.
Never tried the coconut though.
Lee
Mike McCoy
>I just hand them to my Macaw and he makes short work of them. Of course, he's not real good at sharing either. :)
>You could always do what they do on the Eastern Shore. Throw the black walnuts (with the outer husk on) in the oyster shell of the driveway. Drive over them a while as you use the driveway. After a while the husk comes off and they are ready to crack. I suppose it would work for gravel also.
Pete in Holland, MI
>Did a test in college about the cracking point of various nuts. Brazil took the highest efforts. Seems it took an average of 230 pounds of force to crack the shell.
Think about that as you feed your parrot nuts with your fingers, and watch Polly chomp on one of these with little effort !
Mike McCoy
>:) This guy has been with me for over 30 years so we have a pretty fair understanding of capabilities. :)
>I forgot about the vise. I remember now a method I used long ago - I'd put pressure on the walnut with a big C-clamp until it started to crack, then smack it with the hammer while under pressure. This seemed to crack more evenly.
I read once to soak the nuts in water for an hour or so before cracking to help prevent shattering the meat. I haven't tried that yet.
Paul Blackwell
>Try putting them in the freezer overnight, and then crack them with a nutcracker. Works most of the time.
paul waddle
>I'll try the freezer. As far as walnuts go,its the variety or type, that cracks the easiest(as per Bluhmers-commerical nut grower).
When I was a kid I cracked black walnuts by the
Don Henthorn Kyle, Texas
>bushel. My Mom insisted that black walnuts were the only nuts worth using in food. We always gathered two or three bushels of hulled nuts every year. I would sit in the basement on long winter nights and crack black walnuts with a hammer. I learned that if you stood the walnut on end and struck it with just the right amount of force there was very little nut picking to do. The nuts USUALLY came out in big chunks and the job went pretty fast. Black walnuts are still my favorite nut.
If I had a lot to do,
Keith Newton
>I would make some kind of holder for the nut, then take my framing nailer, without nails of course, and try shooting the ends with the driver. I'll bet it would not take long to find just the right place to aim that driver..
May need to hold the safety back some way though.
