Shop Update and electrical/conduit question
David C. Lykins - guitardude - Dallas GA
>I actually have one working outlet in my shop (basement is unfinished with NO outlets) now and I've managed to mount four electrical boxes, run the plastic conduit, pull the wire and wire three of the four outlets last night. YEA! Most of my stationary power tools will be along this concrete wall, thus the use of conduit and wall mount boxes. Here's my question, I mounted PVC type electrical back boxes fed with PVC conduit (the grey stuff). Do I need to "glue" all the fitting together, it all fits snugly now, or can I just leave it as is? I was also currious as to the spacing I should use to mount the PVC conduit mounting brackets.
My next run will be for the 220Vac I need for my table saw. Same wall and type of conduit and back boxes.
Any help is greatly apprecaited.
Thanks!
Re: Shop Update and electrical/conduit question
I didn't know....
>I didn't know you could use the grey PVC conduit for electrical indoors. I thought indoors you had to use the metal (EMT) stuff.
Have fun... setting up a workshop is fun!
Happy Woodworking!
>I mounted the metal boxes on my basement walls. I didn't trust the PVC that much. I did run the gray PVC conduit with the PVC screw adapters. I glued the conduit and the adapters together. The inspector thought it was okay - but we're not talking about a big city inspector.
Just an amature, but . . .
SteveM
>If I were useing conduit INSIDE the walls I'd secure it to the boxes. Don't know about code ( although Mr. Holmes won't allow connections of ANY kind behind walls ) but I'd be thinking ahead in case I ever had to push or pull that wire in the future. The conduit will also push/pull/shift if you ever tug or pull the wire. If the conduit shifted inside you MIGHT have to open the wall to get at it. If it can go wrong it will. Just because I'm paraniod does'nt mean they're NOT out to get me.
Re: Clarification
>The boxes and conduit are mounted ON the exterior surface of the cement wall inside the basement. No wires, conduit or boxes are concealed within any of the walls.
Maybe I'll post a PIC' tonight for clarification.
Hope that helps.
All the more reason to secure them . . .
SteveM
>If the conduit were to slip out of the box and move any it'd wear on the Romex. I know they would'nt but . . . I'd sleep better with a tight, secure rig.
The Greatest Achievers Have A Conduit Attitude
Dave Peebles Lyons, Ohio!
JoeW in Detroit, MI
>It looks like PVC conduit is required to be supported every 3ft and within 3 ft of every junction box. When running short run doen the wall for an outlet box, I typically put one at the top ( about 6 inches down) and one within 6 inches of the outlet box. NEC 352.30. It also looks like the joints officially need to be glued per code 352.48.
