Tormek question - that angle setting jig
Mike Schwing from Md.
>I feel silly asking this, but since I can't find my manual which I'm sure is still in a moving box somewhere in my house, here goes.
How does one use the angle setting jig/thing that allows one to properly set up the grinder to sharpen a particular angle.
I simply cannot recall how it works as my Tormek is typically used for turning tool sharpening and once the plane irons are sharpened, simply honing them on the leather wheel is all that is usually required.
One of my plane blades fell out of the plane and crashed onto the tile floor. It needs help!
Tormek wants the serial number for the manual download and I can't remember to write it down. Thank you.
Re: Tormek question - that angle setting jig
>Mike,
Set the angle by placing the "diameter compensator" (the rounded thingy) on the stone and dialing in the approximate diameter of the stone (9.5" or whatever). Set the desired angle for the bevel or edge on the angle setter (the pointy thingy). Align the plane blade to the correct angle against the stone with the jig and the jig holder. If this isn't clear, I'll try and copy the relevant portion and send it to you.
Aha! (I got it)
>Thanks for the reminder. I had it backwards in my head. Tormek to the rescue! (or JL in this case). Thanks again.
Videos..
Tony - Memphis
>at Sharptoolsusa show all that too.
Tony
JohnKJordan in East TN
>Here's a picture from one of the Tormek vendors of use with a plane iron.
