REAL MILK PAINT
Window casings
Window casings
Window casings
Hamish
>I am renovating our bedroom and have added insulation to the inside of the outside walls and covered them with plasterboard. The added thickness is about 2 1/2". We have white pvc inward opening windows that I need to add a casing to to cover the end of the insulation where it meets the window. I left a 3" space between the outside of the pvc frame and the insulation, where I want to add the casings.
Questions 1). I want to make all the wardrobes and doors in the room out of a light oak, so do you think I should do the same for the casings and stool or should I use a cheaper wood and paint them white to match the pvc windows? 2). What casing style should I use? Mitered or butt? As the insulation is set back from the pvc frame, I had thought about setting the side jambs at 45� to the window pane but I'm not sure if this will be too complicated to do, or for that matter look right.
All your ideas will be welcome, thanks Hamish.
Re: Window casings
Re: Window casings
Bill Tindall, E.TN
>there is no right or wrong answer to your question. Do whatever YOU prefer. "You" refers to the decision makers on this project which might include mother-in-law or whomever.
Re: Window casings
Re: Window casings
Lee Schierer - McKean, PA
>I agree with Bill. If the oak is going to but up against the vinyl, be sure to put some clear silicone cault between teh vinyl and the wood to prevent moisture from getting in between if someone leaves the window open and it rains. I would recommend finishing the pieces prior to installation and just touching up the nail holes. It saves a lot of masking.
Lee
