Delta Contrator's Saw mod.34-444
Charles W.Tant
>The mod.34-444 is capable of being changed from 110vots to 220volts. There is a diagram on the motor on which wires to switch. Is that the only step needed? Is it necessary to change the power cord? When using 220v ; what size amp. breaker should be used? I am setting up my first woodworking shop. By using 220v. the motor will develop 2hp. which will be needed to rip 2" lumber I am using to build shop. Is there any reason not to change to 220v? The motor is presently wired for 110 and develops 1 1/2 hp. Is there a particular blade that will be better for ripping roughsawn 2" yellow pine? I have the original Delta blade.Thank you for any help you can give me.
Re: Delta Contrator's Saw mod.34-444
Re: Delta Contractor's Saw mod.34-444
>Look on the Data Plate on the motor and it may tell you the minimum breaker size. It's probably twenty amps, but I am not sure. If the saw came wired for a convertible motor you probably don't have to change the switch. For 220/240 you should have a double pole single throw switch. Hopefully it came wired that way.
A good 24 tooth thin kerf rip blade will help with the ripping. I have to admit I don't use one. I keep a combination blade on my saw and use it for just about everything, but if I were going to do a huge amount of ripping in thick stock, I would switch. You might consider a Teflon coated blade to reduce the pitch build up from the pine.
JohnFoster
>The best thing I ever did was to start to operate my 34-444 on 220 volts! All I did was change the motor wiring and the cord plug end. The saw performs much better, I seem to trip the motor reset much less often, as well as fewer trips to the basement to reset the breaker. The receptacle the saw is on is 220V 15amps.
interesting
Tony - Memphis
>I've been using the same saw for around ten years on 110V and never had any issue with it. I've cut everything you can imagine on it. I don't think you'd need more than 1 1/2 hp (well, rated anyway) to cut pine at any thickness. A good blade and especially with pine, a clean blade makes a big difference. I didn't even realize it could run on 220!
Tony
Re: interesting
Chuck in ND
>I have the Delta 34-444 tablesaw also. When I bought it new in 1995 it came with a 30" Unifence and a mobile base makeing it a 34-445X. I ran the saw for many years on 110 triping the breaker in the breaker panel occasionally when I really pushed it. The problem was when I had it on 110 I had it on a circuit thats was powering other things such as lights, etc. If I would of had a dedicated 110 circuit just for the saw I probably would of solved the problem of triping the breaker. Anyway, a couple of years ago I I had a breaker panel put into the shop wireing because I needed 220 for a dust collector that would only run on 220, so I had three 220 circuits run, one for the DC, one for a air compressor, and one for the tablesaw, plus I reconfigured the 110 wireing in the shop to balanced it out better. I wish I would of wired that saw up to 220 from day one, it made a big difference. I also would like to recomend a Fenner Drives PowerTwist link belt to replace the old stock V-belt, they will make the saw run smoother. For anyone looking for a better dust port for this saw I have designed a new one from sheet metal that flows better and is easier to hookup than the generic poorly thought out plastic ones. As far as the blade that came with the saw I think I still have mine and never used it, It's not a carbide tipped blade. All said, I'm happy with the saw, it's seen alot of use and no sign of slowing down anytime soon.
Some of the Delta motors are 2hp at 240v
Stephen in Frankfort KY
>Some of the Delta motors have a second set of windings that are rated at 2hp when connected to 240v and 1.5hp at 120v. My Delta 36-441 has this motor. It is rated 12.8 amps at 120v and 8.6 at 240v.
Keith Newton
>You should change the plug on the end of the cord, rather than wiring a 110 outlet with 220 You should change the cord end as well to match your new outlet, otherwise someone may come along and plug something else into it and fry that tool at best, and at worse, well,,,,,,,,, you know.
When I have lots of ripping to do on the contractor saw, I use a 7 1/4" blade. The extra torque gained by using a small blade, is like getting another HP.
For the cabinet-work, or finer blade, I normally run an 8". The normal kerf is thinner on the smaller blades, yet the smaller diameter makes it stiffer than the larger blades of the same kerf thickness, so there are other benefits.
Keep the big blades around for those times when you need it for the thicker work. The price is cheaper as well. In fact so cheap, you can just throw them away, rather than sharpening.
Verne in NJ
>I switched my contractors saw to 220V a while ago, following the wiring diagram on the motor. I have it on a 20 amp circuit, and I've never tripped it. The biggest difference I found was at start up. At 110 the motor seemingly had to wind up to full torque. At 220 it's at full speed immediately. Also there's no laboring under heavy load.
As far as ripping power goes, using a thin kerf Forrest ripping blade my saw had no problem ripping 2 1/4" ash. You can't feed the wood that fast, but with an aligned blade and a good fence (I've got a Bies) I got very clean cuts.
For a time I was considering a 2 hp motor for my saw. I checked with Delta, and they said it was fine, you'd just have a problem with the motor peeking above the tabletop if you tilt the saw to 45 degrees. I ended up not doing it.
I also rewired my Delta 1 hp bandsaw to 220. By the way, I did rough ripping of the ash on my bandsaw and it worked great. Much safer because the stock was a little cupped.
Actually, I don't think that's true.
Rod Peterson -- Ormond Beach
I've seen Rick Christopherson address this issue (maybe even here at WC) and without trying to put words in his mouth, there was never a dual winding motor. As I recall, it was simply derated at 120V to permit a UL listing for cording and use on 15A circuits.
If you think about it, it doesn't even make sense to produce a dual winding motor at the price point of that saw. The story has taken on a life of its own and is something of a woodworking urban legend.
Rod
Keith Newton
>I guess I failed to mention that I usually run my little saw on 220 also. The only time I run 110 is when I am out on a job where i can't pick it up somewhere. I put a 2 hp motor on this little 9" contractors saw the first year that I got it in 1977. i put an open frame motor on, because of the reason that you gave for the 45� tilt.
After 30 years using an open frame motor hasn't been a problem so far. If someone know of a problem of using one this way, I would like to know what the problem might be. Otherwise, I guess 30 years speaks for itself as far as endorsements. Before I did this, I knew several old carpenters who had open frame motors on their saws, so I am not making any claims for originality, just passing information along.
I thought I might mention that I also have two other TS's. A 3 hp unisaw, all tricked out, and a bigger PM 5 hp 12" - 14". I know that I risk sounding like a bragger. I only state this, because since we don't get to visit one another's shops, when offering advice on small tools, one might assume that if you only have a small saw, that the advice given is from a beginning wood goober. I though it might mean more if you knew that I am a serious wood working goober of long standing. ha
Yea, the extra power on the BS is a great benefit also. I switched the 5-hp on my 36" out for a 7.5 hp a few years ago, and I don't know how I lived without it being this way for so long. After making the change, I found that Tannowitz puts a 10 hp on theirs, but it will cut 20" under the guides, and mine will only cut 16" depth, so the power per inch of thickness is about the same.
Looks familiar!
Tony - Memphis
>That's probably around the same time I got mine. Mine came with the regular fence and I later upgraded to a Beis. I did have an issue with the motor not starting. It was just out of warranty, but the folks at Delta sent me a brand new motor free. I was impressed with that! I'm in no hurry to rewire anything, but what makes it so much better with 220? My saw has never had any issues with power that I have noticed. I'd like to get a new cabinet saw (like the PM 2000), but I can't justify it. This one does what I need it to I guess. Someday!
Oh, I just remembered, my switch went out recently. That cost a few dollars at Lowes.
Tony
Re: Looks familiar!
>> …but what makes it so much better with 220? My saw has never had any issues with power that I have noticed.
The answer to your question is, nothing, usually. If your saw is running on a dedicated 20A 120V circuit, something less than say 50' from the breaker, you probably won't experience any difference at all. Based on your statement, it's reasonable that you leave it alone.
Just so you know, however, aside from having to run a 240V circuit where you don't already have one, it's about a 30 second job at the saw to change it—remove the cover, change a couple of jumpers, replace the cover, and Bob's your uncle.
Rod
Thanks
Tony - Memphis
