Have a question? Ask Woody!
The TV Stand Project
John McGaw
>Well, I finished the MDO TV stand that I mentioned a couple of weeks ago. As you can see, the design itself could hardly be simpler. Roughly 57" X 13.5" X 17" including a hidden base which "levitates" the big box 1.5" above the floor. The carcase is MDO painted with auto primer and Krylon gloss spray. The interior is painted with flat black. The entire outside was given several coats of satin water-based poly and a coat of wax.
The trim is made of "lyptus" which was scientifically chosen in that it was on the top of the stack and was obtained as a free sample from the vendor. Honestly I can't say much good about the piece I had but I may just have gotten a bum sample with all the checks and cracks in the universe in it. The trim has a subtle chamfer on all edges which results in a bit of a shadow line to set it apart from the carcase. The shelves and partitions are recessed a bit in the back giving room for cables and allows the cabinet to sit fairly flush against the wall without interfering with wall plugs, cable jacks, and the like.
MDO proved to be less of an advantage in this project than I had imagined and probably doesn't justify the elevated cost. And it seems to be heavier than similar plywood of the same thickness. It does have one nice advantage in that 3/4" MDO actually does measure precisely 3/4" which made the rabbets and dados a bit simpler. But any way you look at it working alone with heavy sheetgoods in a very cramped shop with low ceilings is not a fun thing and reminds me why I've always preferred "real" wood. Oh, and Bondo makes for great repairs on MDO plywood when a brad goes astray and comes out the side or a miter doesn't fit quite as tightly as you might want.
Now I need to get busy and repair the damage that was done to the wall in my misguided efforts to hang the LCD. Advice: if the urge ever comes to you to hang a flat screen TV, think long and hard about how much it weighs, how difficult it is to mount and dismount (especially alone), and how often you actually may need to get behind it to change the wiring. That last one is probably more than you suspect.
Re: The TV Stand Project
>Good design and work. I like the honesty in the piece. I agree with you about the MDO; one project was enough for me. MDF or baltic birch are better choices.
For filling dings in work that's to be painted, I use Durham's Rock Hard mixed with white or yellow glue. It's inexpensive and tough.
Clint
Right Behind You
>Thought I might get to some turning, but SWMBO's new LCD arrived today. New TV "demands" a new stand to hold it at the proper height and house the audio, etc., so the lathe will just have to wait a little while longer. Just happen to have some cherry ply left over from doing a friend's rec room entertainment wall, and she does like cherry . . . .
The danger here is that this would be the only cherry piece in the room,
and
the couch is 12 years old . . .
and the bookcases are 25 years old . . .
and
Boy, am I screwed . . . . .
PS
>Nice Job, btw.
