Hope this will help you.
John Cotten
>There are basically two different grades of laminate. Vertical and horizontal. Vertical grade is used on post-formed countertops because it will make the bends required. Horizontal grade is much thicker, it is what a custom top maker will use on the horizontal tops for kitchens, labs, etc.
As I have mentioned before, stop by a cabinet shop or top shop. They usually have some scraps or bad sheet they will sell cheap or even give away.
If you are looking for Melemine (film laminated MDF) This is the white material you usually see in DR.s offices, or other office buildings. I just bought a lift a couple of weeks ago, was around 20.00 a sheet for 3/4 stock.
Ask locally at your neighborhood cabinet shop, they will usually tell you where they are buying their sheet goods.
If you are close to Danville,KY, call me at 859-583-7881 and I'll help you get what you are looking for.
