Prime MDF Before Cutting?
Dave W
>I'm in the planning stages of building some simple bedroom furniture for my daughter. I'm planning on using MDF for the carcase construction. Does it make sense to pre-prime the MDF by painting the entire 4x8 sheet(s) prior to doing the cutting, edging and assembly? Is this common practice? Will it mess up my saw blade and router bits?
Any information that you care to share would be most appreciated. I've built some basic shop jigs, etc. with MDF, but this is my first attempt at furniture.
thanks,
Dave W.
Re: Prime MDF Before Cutting?
Ron Hildreth, Alta, Iowa
>Dave,
I think you'd be better off doing the assembly first, especially if you're going to paint it. Makes for a much better glue bond at the joints, unless you plan on doing a lot of masking first.
Ron in Iowa
Second Rons comment...
John Cotten
>Also predrill and use 2" screws for you carcase assembly.
Dave W
>Thanks guys. I'll prime after assembly and use the 2" screws. Don't want to risk glue joints failing!
