Any tips on working with Formica? *LINK*
Dan Mitchell
>I posted awhile back about what material would be best for an outfeed table for my cabinet saw. Based on my inability at the moment to transport anything much bigger than a 2' x 4' sheet, I opted for the high pressure laminate rather than the easier/cheaper/it-won't-fit-in-my-car melamine. So I have constructed a table out of 3/4" birch plywood. Top is 4' x 4' (2 2' x 4' sheets). I ripped a 3rd sheet of this plywood into 2" wide strips for bracing along the edge and across the bottom of the top. I could have used 2 2' x 4' melamine pieces, but I wanted to avoid a seam in the top. I have a 4' x 8' sheet of white high pressure laminate, a can of Wilsonart 600 contact adhesive, a low nap 3" roller, and a J-roller. I know the basics of how to do this (I've seen it done on TV, anyway); roll on the adhesive to both surfaces, let it dry until tacky, put sticks on the table top, place the sheet on the sticks, remove the sticks & hope like hell the bloody thing is positioned OK, then roll it flat with the J-roller. My concerns are how best to cut the 4' x 8' sheet into a piece about 48.5 x 48.5 for the top (I have cut this material a couple time in the past using a scoring blade in a utility knife, I'm wondering it this is still the best method), the initial positioning of the glue-backed sheet, and trimming the edge of the sheet once it's in position. I bought one of the flush cut bits shown in the link below, hoping it would be suitable for the trimming as well as other projects in the future. Any helpful hints on any of this process would be greatly appreciated!
TIA
Dan
WHITESIDE Over-Under Flush Trim Router Bit
Re: Any tips on working with Formica? *LINK*
Eric Kuehne
>Dan,
Sounds like you've got the concept down. The first time I did it I just applied what I had seen on TV. Worked great. I just cut the laminate with a saber saw and go about 1" overlap on each side. Just cut slow and use a fine tooth blade and you should be fine. BTW, if you are going to do the edges do them first. In these situations I usually come back and put a very slight chamfer to the edges. You really want to avoid going thru the material.
Good luck!
Eric in Los Gatos
a couple of tips.....
R. Lance in GR, Michigan
>I've had success cutting formica to size by using a small 1/8" spiral router bit with 1/4" shank that comes in one of those patch/inlay kits. Cut the piece about 1" more than you need in all directions. If you can, do the glue up outside (or at least with all the windows open)...those fumes are strong. You've got the method with the sticks...except there is no "hoping" you got things placed right...take your time and position the formica over the substraight taking advantage of that extra inch and begin to put them together by removing a stick from the center and with a little pressure push the formica onto the substraight without moving the formica...once contact is made, thats it...they are bonded...remove the next stick over and make further contact with the formica/substraight moving from the center outward toward the edge...you are trying to avoid air pockets....to trim the finished edge, use a straight edge trimming router bit with a bearing....a like to follow that with a chamfer bit with guide bearing to give the edge a nice little detail....do that to your own taste....best of luck and enjoy the new table.
Re: a couple of tips.....
Chuck in ND
>I'd like to also say that you need to make sure the wood surface and the underside of the laminate are completely free of any foriegn objects. When I did my kitchen countertops many years ago somehow, don't ask me how, a chip of wood or something small got traped between the wood surface and the laminate leaving a small high spot. I don't know what got in there, maybe it was in the glue, I guess I'll never know.
laminate knife *LINK*
Andrew F in Australia
>Hi Dan,
use a laminate knife according to these directions - there's a thumbnail picture of the beastie in use.
Cheers,
Andrew
click here
>I used to this a lot. I noticed the word "tacky" in your description of letting the glue dry. I have always found it somewhat amazing that the glue seems to be dry, not really tacky when its ready. You can touch it and not pick up any on your finger tip. If your finger still sticks or you find it soft and gooey, its too wet. So, let it dry longer than you think, or at least longer than I think.
I really like the bit you posted, had not seen one like that. It will do the job nicely, but will leave the edges sharp. Really sharp. Most people bevel the edge to make it tougher and less prone to chip and to make it less likely to cut you. If you don't want to buy a bit with a beveled cutter in it you can "soften" the edge with a file or fine rasp. Just a few strokes all the way around to knock off the sharp edge. (Trust me, you really don't want to leave that sharp edge lurking.)
You did not mention what you are doing for an edge treatment. Are you leaving the plywood showing? Are you gluing strips of laminate on the edges? Or are you binding the edges with something like hardwood strips? If you are leaving the plywood showing, just glue on the laminate and trim the edges and file them smooth. If you are gluing laminate to the edges, do them first. They look a little better if the top goes over the edges and they are less subject to getting the edges snagged and pulled off. If you are putting hardwood strips you can do it either way. Put the laminate on the top, trim the edges and leave them sharp and square and glue on the hardwood, then use your bit to flush the hardwood to the top. Or you can put the binder strip on first and glue on the laminate and use a bevel trimmer to put on as much bevel as you want, exposing some of the hardwood on the bevel.
You can use sand paper to soften the edges, but I would use really fine and put it on a block to avoid scratching the white surface.
Also, You did not mention slots for the Miter gauge in your table. The miter gauge slides past the back of the top of the saw and must have clearance slots in the out feed table. Those slots are likely to be too shallow to allow for the bearing on your bit. You may have to get one of the solid one piece laminate bits. Its a quarter inch shank with a notch in the side that creates a cutting edge and leaves a rubbing surface on the bottom. The little nub on the bottom is short enough to ride in the slot for the miter gauge and cut the laminate off the top of the slot.
It would have been better to use balanced construction. Two layers of plywood and laminate on both sides. Seems like overkill, but countertops often warp unless they are well braced.
Using horizonal blinds
>I always use aluminum horizontal blinds instead of sticks. Put the concave down (rounded part at the top, two ends on the bottom). Using these really helps the critical glue alignment contact step. They are very lightweight, provide almost no contact with the glue, are slipery enough to slide out easiyl, and have a little bit of bounce which makes it easier sometimes. Start by removing the centers ones and then works outwards.
When I install aluminum horizonal blinds on my windows, there are always half a dozen or more extras when you shorten them (shorten the height by removing the bottom slats, not shrtinging the width). Or you can get them from your neighbor's garbage from time to time.
Happy Woodworking!
dang ya stole my tip :-)
Gary Camp, Bend, Oregon
I use bamboo plant stakes
Neal in San Jose
>Easily available in various lengths, cheap, and when you are done you can use them in the garden!
Ooops, sorry ;)
Bamboo Stakes ?!?!?
>That just sounds so unappetizing. Unless you're a Panda bear I guess ;)
Happy Woodworking!
Dan Mitchell
>Thanks for the great suggestions. I plan on putting a 3/4" poplar border around the trimmed laminate/plywood edge on the 3 exposed edges. The laminate knife is what I had used year ago on a kitchen remodel (backsplash, never glued a countertop). I'll pick up some of the blades. The Venitian blind thing sounds like a GREAT idea! Wish I had some! I had planned to use a straight cutting router bit for the miter grooves, scoring the top along the outer cut lines. The underside of the table has a pretty good amount of bracing using 2" wide rips of the 3/4" birch plywood. All around the 4 outer edges, 2 more running cross wise, and 2 running lengthwise between the 2 cross members. There's also a 2" strip glued/screwed flatwise under the seam of the 2 2' x 4' sheets. To my surprise/dismay there's still a slight dip where the sheets are joined. Not huge & shouldn't make any functional difference, but given the amount of bracing across the area I would have expected it to be perfectly flat.
Thanks again for the advice!
Dan
Jim Dillon
>Dan,
Yet another way to cut the laminate, and use your newly purchased flush-trim bit is as follows. Mark where you want to cut the laminate on the back side (not the good side). Then clamp a board with a nice straight edge even to the line. Flip the laminate over and keeping the bottom bearing against the board, cut the laminate. The one problem with this method is keeping the clamps out of the way of your moving router base. The weight of the router helps keep the laminate tight against the plywood. Truth be known, I would just use a cheap laminate scoring knife with a straight edge clamped to the good side. But I wanted to suggest a method for using that new tool 8-).
Jim
Laminate knife rough cut
>Hi Dan,
From reading your second post, it's a little unclear to my reading as to what you're doing with the laminate knife so I thought I'd clarify.
I should have mentioned that the laminate knife is a rough cut only. Cut the laminate approximately 10-15mm oversize each edge.
The final trim is done with a trimmer and a pilot guided bit or a bearing (a trimmer is the 30000rpm small router about the size of a pint of milk or so.)
Hope that it goes well.
Cheers,
Andrew
the router bit you bought is the correct one
>The trimmer is a one-handed tool used to trim edges of laminate where the bearing surface is 18mm wide or so and the board is standing on edge, that a full-sized router can't be balanced on.
The half-inch bit you've got there should be perfectly OK in a full sized router for edges.
Cheers,
Andrew
Re: the router bit you bought is the correct one
Dan Mitchell
>Andrew-Thanks for the replies. Yes I plan to cut the laminate roughly to size with the scoring knife, glue it in place, then route the edge. Glad to know I got the right bit!
Dan
