best material selection
Earl Rogers
>I am building a wall that will consist of approximately 14 1x10 x8 standing on end. the boards will be set at a 45 deg angle so that you can not see through the wall from one end and can see through the other end. something like this / / / / / /. The wall will be 7ft tall. I do not plan to block at mid height. I want smooth finish on sides and edge.
What would the best selection of wood product. MDF, dimension or plywood.
Re: best material selection
>It'll be pricey, but the easiest and best would be 1x10 (actually 1x9.5) finger jointed poplar trim boards. Even pricier would be Azek trim boards.
Clint
>I might be wrong, but I would be leery of MDF unless you hang it from the top. It tends to sag over time. I probably would use plywood, but I am not familiar with the material Clint mentioned.
JohnKJordan in East TN
>This is an interior wall?
I'd worry about 7' long solid wood boards warping if supported only on the very ends.
