Dial Indicator
Tom Norton
>I need to geta unit with some different"arms". I will be using it to set up my thickness planer.
Any suggestions on brand? Used is a possibility.
Dial Indicator
Tom Norton
Re: Dial Indicator
SteveM
>Dad is a tool & die maker and I asked about the used issue. I picked up a indicator, stand and granite surface plate for under twenty bucks on the bay. I noticed there were plenty of magnetic bases also cheap. Good makers too ! I was mystified by the prices. He said that once they leave the factory to a user after that they are worth nothing to a " certified " ( ISO, etc. )user. They don't know how they've been handled or used. So once a " private " user gets it and it checks on a " standard " ( " known " gauge block, pin gauge, etc. ) AND the mechanism works properly, " used " will work well. Personaly I've got a digital Mitutoyo indicator ( I have a hard time remembering what a dial said in the first place ! ). I like the zero button. Just throw it on the work piece, hit zero and your off and running.
Re: Dial Indicator
Chicago Bob
>Check with lee valley (leevalley.com). I have their digital version and it is accurate & very easy to use.
good luck
Bob
Re: Dial Indicator
Paul Waddle
>I need a 'paddle' foot for my dial indicator so I can measure runout on a threaded shaft. I can't seem to locate one to fit my starret gage. Wonder if I should just get a set on ebay?pw
Re: #4-40 is a common thread for dial indicators.
Al Crandall
>I have made long thin points for dial indicators by silver soldering an allen wrench into the head of a 4-40 socket head screw. After grinding the wrench to a sharp point the screw was installed in the indicator. A paddle foot could just as easily be the attachment soldered to the screw head.
Re: Metal woking catalogs... *LINK*
Rick L
>Don't even bother with the woodworking catalogs for this item. Go to the metal working catalogs like www.use-enco.com or my favorite www.wttools.com You can buy a new import indicator for under $15. Tips and bases are available too. Plenty of great prices on calipers and any kind of measuring tool you need.
Indicators
Re: Dial Indicator
peter kolb
>Paul What is a "paddle foot"? Peter
Little Machine Shop has good stuff cheap *LINK*
Tim Greif - West of Chicago
>See below and take a look around their site. I bought a dial indicator and caliper kit from Grizzly for $30 and then got the indicator point set from these guys. Here's one set all together minus the caliper. Very reasonable prices.
Little Machine Shop
Re: Dial Indicator
Paul Waddle
>Ha ha,I have no idea-someone said that I needed a 'paddle' foot.I want to measure run out on a threaded shaft,so I need a flat foot to span two or three threads-the semi ball foot jumps around. pw
