Should I keep the Bandsaw
Roger
>Earlier I was seeking information on the RIKON, 10-345 as a replacement for my 14" Delta bandsaw. The Delta is USA made with a riser block, all of the Itura Upgrades and a Woodpecker Table System with circle cutter. I just bit the bullet and purchased a Mini Max 16 and am considering keeping the Delta but am not sure why. Would you keep the Delta or get rid of it?
Roger
Re: Should I keep the Bandsaw
>Good Evening Roger,
Two saws may save set up time. I presume the Minimax will do everything the Delta can do, so you can only benefit by carrying two set ups. After all, some folks retain one cabinet saw for ripping while using another is configured for cross cutting or dado work. I too have multiple tools! like pencils. :<)
George
>I have a very similar band saw with similar upgrades, maybe not quite as spiffy as yours, but similar. I have a love/hate relationship with it. Part of that is that if I want to resaw, I have to put the resaw blade on and tweak it to do that, (30 minutes to an hour or at least it seems like that), then if I want to cut any sort of circle, I have to put the circle cutting blade on a tweak it again. (another day and a half or whatever it takes). Everyone I talk to says the answer is TWO bandsaws. So if I had the money and the room in my shop, I would get a real bandsaw to resaw with and keep this one to remind me of how it used to aggravate the H.... , No, I mean to cut circles.
Yeah, 2 bandsaws are ok.
Eddie Pacheco: San Jose, Ca.
>When I purchased my used 18" Laguna saw I was intially planning on selling my 14" Rockwell-Delta saw as I really don't have much space in my garage/shop. After several weeks of putting off listing it I had a situation where I needed a 1/4" blade and the Delta was already set up with one. Now I make do with a little less space and two bandsaws.
Jim DeLaney, Austintown, Ohio
Re: Keep Both Bandsaws
>Definitely keep both.
I've had a Laguna LT-16 for about four years, and kept my circa 1981 14" Taiwanese bandsaw, too. I find that I use both of them - a lot.
I generally keep a half inch resaw blade on the Laguna, and a 3/16" blade on the 14". That way, I can do both big and small stuff without changeover. When a 'big job' requiring a lot of tight radius cutting does come up, I do switch the Laguna over to a 3/16" or 1/8" blade, but that really doesn't happen very often.
Jim D.
Two in the hand . . .
SteveM
>beats one broke and no spare ! If its paid for how much space could it take up ? Could store it here.
David Yoho
>I had that exact situation several years ago. I opted to keep my Delta for cutting everyday stuff and the MM-16 for re-saw work. I have a 1-inch carbide toothed blade installed on the MiniMax and didn't like the idea of changing the setup, so I kept the Delta and it's been a good choice for me.
David
Jim Shaver - Oakville, Ontario
>Hi,
Like the others have said I'd keep both. I have been thinking seriously of getting rid of my TS and buying a second bandsaw with a large cutting base. Something like an 18" Laguna.
Take care,
Jim
Re: I've got two...
>my old Delta 14" (without a riser block, but with the other enhancements) and my Rikon. I use them both.
Re: I've got two...
Ron Hildreth, Alta, Iowa
>CRAP! Now I gotta buy another band saw!
Anyone here have the last name of Jones??? (say yes- makes for a ligitamate excuse to give to the wife!!)
Ron in Iowa
Roger
>It's unanimous, I will keep the Delta bandsaw.
Roger
Michael Wilkins
>Your question is exactly the reason I am looking at smaller bandsaws to supplement my Laguna LT18. With a 2nd machine, I can keep a wide resaw blade on the big guy, and use 1/4" or smaller blades on a smaller machine for the curvy/scrolly stuff.
The 10" machine from Sears @ $99.00 is looking really good, but I may hold out for the Rikon 10" machine.
Besides; there is no such thing as too much iron in the shop, unless there are space considerations to deal with.
Good luck and watch those fingers.
peter kolb
>I have the min-max-16 and a Kity 12 in MM16 wears a 3/4 inch band and is used for ripping, general cutting and trimming bowl blanks to size but no circular cuts on the bowl blanks. The band is 148 inches and because of its size is a pain to change My go to machine is the Kity and is used almost every day.(I'm retired) Tensioning the MM16 is another pain but the Kity it is a snap. The Kity is a excellent machine and was very expensive in 1992 when I bought it. Peter
