the angle
Guy P. Boucher
>What is the angle on a 6-sided window
the angle
Guy P. Boucher
Re: the angle
Charles
>The interior angels of a hexagon are 120 degrees each. The exterior angles or the cut angle are 60 degrees.
Re: the angle
Guy P. Boucher
>Thank you Charles.
60*
For future reference *LINK*
Charles
>Rockler has a set of pages on Woodworking Math, including cut calculators.
Woodworking Math Tables, Formulas and Calculators
I think I made a mistake!
Charles
>Depending on how you orient the wood, you will most likely need to make a 30 degree cut.
Re: Cuts
>If you are mitering flat stock to make a hexagon, your blade should be tilted precisely at 30*.
For ripping a bevel, you should also consider setting your TS fence so that the workpiece is above the tilted blade and riding on the fence. For right-tilt saws this means moving the fence to the left side of the blade. Otherwise use the miter guage or a cut-off sled to control the workpiece.
For a chop saw this is a no-brainer. The angle is 60* so you cut each piece at 1/2 the angle - 30* to make the 60* miter.
mm
Blade angle = [180�/(number of sides)]
Andrew F in Australia
>eg: to cut a square sided box, blade angle = 180/4 = 45�
to cut a pentagonal box, blade angle = 180/5 = 36�
to cut a hexagonal box, blade angle = 180/6 = 30�
to cut a septagonal box, blade angle = 180/7 = 25.7�
Cheers,
Andrew
Re: the angle
Guy Boucher
>Thanks all for your help. I love this new place I have found for us want to be workers. So much great information and so many great people.
Thanks again
Phew!
Charles
>I hope you didn't cut anything based on my first answer! Glad you got a better answer.
