evening out color of mahogany
ed mccormack
>ok im on to another cradle, I was given some mahogany I edge glued the boards together and almost each board is a different color. Iam wondering if i stain them as they are will they be different in color. Im also wondering a good color to use i have some brown mahogany stain but its too dark, lookin for a lighter color.(would a honey or pecan work)? I've been reading online about bleaching wood will this work and how complicated is it? Thanks for all your help in advance.
Ed
Re: evening out color of mahogany
Getting the color you want
>If you're determined to use the wood you have, you can always make it darker with stain, but never lighter (unless the stain is opaque, I suppose). Dye stains do a better job of giving a uniform color than do pigment stains. If you really want it lighter and of a different hue (i.e., brownish/yellowish instead of reddish), you can bleach the color out using a two part wood bleach (Kleen Strip makes the most common one -- available in paint stores) and then stain it any color you like.
If it were me, I'd save the mismatched mahogany for another project (or several projects) and use a wood that is the right hue and value (lightness/darkness) to begin with.
My 2¢,
