Is it possible to make this with a router?
lee beeden
>I know that you can make turnings with a router, but how detailed can they be? Is it possible to make anything like the turned legs on this table? I would be very much interested to see what YOU may have achieved with a router and jig.
Many thanks
Lee
Re: Is it possible to make this with a router?
>Lee, I got the idea of combining my router and my lathe. My idea was to put a big bit in the router and a huge rough blank on the lathe and use the router to "rough" the blank to round. So, to see if it would work I just held the router up to the tool rest on the lathe. Sort of a proof of concept attempt. If it worked, I was going to make some sort of bracket for the router. It took about a tenth of a second to find out it was a bad Idea. I threw the bit away and In another year or two I will have the damage filed out of my tool rest. So, whatever you do, mount the router securely, don't just hang on for dear life.
To your question, I think the answer is yes, but I am not willing to try again.
Thanks Barry!!!!!!
lee beeden
>Thanks Barry!!!!
I wont try that idea in a hurry!!!!!! What about forgetting the lathe altogether, could those legs be turned with just a router and Jig? You've probably guessed by now that I don't have a lathe and would love to make a table like that!!!!
Thanks
Lee
>I can be done to some extent but you have to build a table for the router to ride on. Then you have to build a jig to guide the router. You are pretty limited as to the shape unless you change bits often and this probably means changing the guide jig as well. If you made shallower details then you could probably use 1 bit and 1 jig and do a pretty decent job.
I tried using the router to rough out my mirror handles and it does work but I can do it almost as fast with a rough out gouge and skew so I quit trying.
Tony - Memphis
>I don't think it would be practical. You'd have to get a bunch of router bits to make that profile. You could try a mini lathe or try tablelegs.com. They have some really nice legs. Adams in TN has some nice ones too. I think there is another company called Osbourne that sells legs. Or, head over to the turning forum and ask if anybody is interested. Maybe someone in your area will help/let you turn them on their lathe. Good luck with it.
Tony
Sure. All you need is some ingenuity and
Forrest Addy
>Sure. All you need is some ingenuity and some simple jigging out of wood. The better the jigs are designed and made the more productive and versatile they would be. Consider the tapered octagonal posts Norm Abrams made on that colonial bed in New Yankee Workshop some years ago. http://www.newyankee.com/getproduct3.cgi?206 Very simple but effiective equipment; almost elegant.
When you consider a cutting tool (that's all a router is is a powered cutting tool) as such you are free to exploit all its properties and capabilities your native wit will allow. When it comes to making those turned legs I can visualize the blanks being mounted on screws through their centers on vertical supports with the aaxis parallel to a flat surface. The router is mounted on a sled that cna be move around on the flat surface so the cutter can get to any part of the leg. Mounted above the leg is a template. On an extention ot the sled is a follower precisely the same shape as the cutter in the router. The work is rotated by hand as the router is manipulated to trim away (not too agressively!!) the waste.
Assemble all that and you have a router duplicator.
steve - Denver
>Have you looked at the Legacy Mills?
http://legacywoodworking.com/products.cfm?product=126
Absolutely!!!!
>You mount your router in the Legacy Mill and have at it to the template you have made.
I seem to remember they run around $15k but I could be wrong.
Of course, that's getting a bit expensive for 4 table legs that you could knock out on a $300 lathe with some basic turning tools or buy for $25 each. |;-}}}}
Why hasn't Bill Hylton jumped on this thread? |;-}
mm
Bill Hylton has a machine
Curt Harms
>in one of his books-I think it's "woodworking with the router" but I'm not sure and am not home to check. He has a homebuilt machine that looks much like a legacy mill to my eye.
HTH
Curt
Re: Absolutely . . . .WRONG *LINK*
>Should have checked before opening my mou . ., um, fingers.
You can have your very own Legacy for what seems the pitence of less than $2,500!!
Legacy
>Many things are possible that are not very efficient. The advantage of the lathe is the ability to spin the piece at speed for sanding.
A question for you Lee?
>Do you want to make the table as in do all the work yourself or do you want to end up with a table? I would collaborate with you and turn the legs for you or you can post the question on the turning forum and see if you can find someone closer to you. Shipping them back and forth might be a killer. And, As other shave pointed out, you can buy legs in a number of places.
I have been thinking about doing this with a router, but Moses is right. Even if you set up some sort of system and bought any necessary bits, you would still end up with legs that needed sanding. Probably a lot of sanding.
I had some oak 4 X 4"s that cracked. I gave them away as fire wood. If they have not been burned, I will get them back and let my neighbor freeze. I could turn your legs from them and you could paint them as shown in the PIC. If you are interested, let me know and I will check to see if the wood survives. IF it is still extant, I will give it to you and just charge you for the turning and shipping.
YUP what you want is *LINK*
Bill Hammond, Oregon Coast
>A Sears Router Crafter. Made way back when. You mounted your router with a small bit and used a template. I had one back then and it was interesting to use. Made a lot of noise compared to a lathe but it was easy, no skill required, and the copies did turn out the same. Only needed to sand the piece when done.
Oh yeah, it was slow too.
Bill
Here is an old listing on ebay
Re: You mean mine could be worth that??!!
Brian in Brighton
>I have one of these things gathering dust in the rafters. Are you telling me that the router crafter I bought for $100 14 years ago is worth over $200 now? I might unload it just to be able to buy another router.
Brian in Brighton
Re: A question for you Lee?
lee beeden
>Thanks Barry!!!! A very nice offer, but I had intended to make the table myself. Judging by all the feed back the lathe is the sensible option and would be very welcome in the shop. Time to manifest some more cash!!!!! Perhaps I'll bug ya for a few pointers when I'm ready to start? Thanks again
Lee
Thanks for all your feedback!!!!!!!!!!!!!!!!
lee beeden
>That's a good starter project for learning turning. Nice sturdy spindles. Nothing to worry about in terms of the blanks whipping or chattering.
Read up on turning matching spindles. Getting the prominent features at the same height and diameter is the important part. I would suggest making a practice one and then turning four to match. Then pick the best four out of the lot. This will also be helpful in setting up the mortises in the tops of the legs.
Just be sure your lathe's bed is long enough for the spindle. Go for it.
OH, and welcome to the slippery slope of turning. Remember, the lathe is the cheap part. Then there is the stand, the chisels, the grinder to sharpen them on, the chuck, the calipers, and....
