Finally a gloat ....
>Picked up this on Friday. Got it into the shop on Friday afternoon.
Got the power cord on Saturday morning and then had to go bake bread all day :(. Sunday I had a lot of church stuff going on, what with the Blessing of the Animals and handing out loaves of bread.
Finally wired it up and got the rails and table on. I checked out the alignment with the tools that I have, and the blade was parallel to the miter slot (better than 1/128"). Put the fence on and it was parallel to the miter slot.
The specs:
Steel City 10" Industrial Cabinet Saw: includes a 5 HP, 230V, single phase TEFC motor with magnetic starter; 50" Industrial T-Square fence system, carbide-tipped 40 tooth ATB saw blade, right laminated extension table, adjustable steel support legs, two cast iron extension wings, table board, standard insert, dado insert, miter gauge, motor cover.
The motor is a 5 hp motor (230 V) and draws about 15 amps +. As the outlet was a few feet away, I used a NEMA 6-30 plug with 10 gauge wire. I suppose I could have used 12 gauge, but I wanted to err on the side of caution.
So, should I put on the blade guard?
