200+ woodworking book reviews
Drooping Ceiling Tile (OT)
Nick Barnes
>I have a 20 year old (?) glued up tile ceiling, and it is starting to droop in our front room. There is a section about 4 tiles square hanging about 3 inches lower than the rest. It seems like the glue has just let loose. I don't see any water marks on the tile, and it isn't under a bathroom.
I was thinking of injecting some super glue thru the small opening in the seam and then pressing it up by hand for a minute or two. Any other ideas?
SWMBO would like it fixed sooner rather than later. Of course.
Thanks,
Nick
Re: Drooping Ceiling Tile (OT)
SteveM
>Replace. Kind of like drywall. Once wet . . . never the same.
Dick Krieger
>I agree that replacement is perhaps only the best method of repair. I had a dropped ceiling in a basement once (2' x 4' panels) of Celotex. After about 8 years, the moisture from the humid Michigan summers began to cause the tiles to "sag". All tiles sagged the same with no other sources of moisture contamination other than summer humidity. Replacement was only cure.
Larry Clinton
>I've never tried it - sounds like it may work. Don't look like you have much to lose, just the cost of the glue and a little time. One thing I have done is to touch up stained (from water damage) white ceiling tile. I found a liquid white shoe polish with the foam applicator pad will touch up the tile leaving an invisible repair.
>I'm with Larry on this. One of my "rules" is You can't break something that is already broken. So take a whack at it. I would try either the glue you mentioned or some kind of Liquid Nails. Try to figure out where the original glue was and shoot some in. To hold it in place I would make a Dead Man. Use a scrap of plywood or a board to press to the ceiling and then attach a long flexible stick to it (1 x 2 or 1 x 3). Practice on an area that is still in place and cut the stick about a 1/4" too long. Put the piece of wood against the ceiling and then flex the stick into place so that it presses the board to the ceiling as it tries to straighten. You can screw or nail the stick to the board and if you cut it too short you can use wedges or scraps under it.
Your other choice is to take the ceiling down and replace it. If you can reach through the cracks and cut the back flange off, you might get it down in good enough shape to reinstall it, but likely you will ruin it. If you ruin it, the chances of finding matching pieces is pretty slim. At best, the color won't match and you will end repainting the whole ceiling.
gm54210\
>too bad about the mess. I would agree - give the glue up a try. zJust make sure the tiles are dry before handling them. There are a number of regluing schemes that work well. So go with the flow and see where the projrct takes you.
You may want to explore using tiles from less visible areas of the room to replace the bad time. It usually works quite well.
Good luck,
wes
