>I am very new to turning and not at all sure about what type of wood to scavenge. A neighbor is about to harvest two podocarpus macrophyllus (yew pine). Is this worth saving for turning projects? If so, what advice would you give me on preserving and turning it?
Free wood is good wood. Any wood you can mount on your lathe is worthy of turning. Give it a try and see what you can make of it.
Post this on the Turning Forum (See the red bar to the left) and you may get more responses.
You can seal the end grain of the wood with wax or paint. You can store the pieces in plastic bags, but if left too long they may spalt (desirable) or rot Not so desirable. If you are turning bowls or hollow forms you can turn it green to finish and let it warp or you can rough turn it, leaving it an inch or so thick and then let it dry and return it to eliminate the warping. There is much to know here. The size and nature of the wood determine the warping and other factors. Lots of factors affect the drying.
>One thing I did not mention is that there is a little urgency about this. Its supposed to be 90 degrees here today and tomorrow. Strange for this time of year. I dont know what your weather is, but the wood is drying as we speak. It is best to leave the wood in the largest pieces possible and cut it into blanks when you can use it. This leaves the fewest exposed ends which is the part that dries fastest and cracks worst. So, turn a little of it and if you like it and want to keep it, move along. Bag, or coat it and get busy turning it. It is drying and cracking from now on. When you cut a blank, you may need to cut a few inches of each end to get to part that has not cracked. So if you were making a bowl, you might have to cut "half a bowl" off each end and throw it away. So if you blank is for a single bowl and it cracks, it would be ruined. If it were for two bowls, you might be able to cut on out of the middle. Your loss would be fifty percent, but not a hundred percent.
