Jet 1 1/2 HP Spindle Shaper
Tom Henderson, Gulf Breeze, FL.
>I bought this piece of equipment used and have happily used it as a router table for several years, but only for shaping edges. Now I want to cut a mortise 1/2"x1/2" into 1 3/4" square stock. Some are through mortises and some are stopped, so I chose the shaper, rather than the table saw.
Now comes the question. The split fence on the shaper doesn't adjust far away enough from the bit (a 1/2'diameter mortising bit) to allow me to place the mortise where I want it (7/8" in from the edge). Is the solution to make my own fence and clamp it where needed, or is there some way to move this fence that is not yet apparent to me? (Parenthetically, I need to tell you here that there are many things that are not apparent to me, most of them having to do with woodworking).
The shaper model number is JWS22CS, purchased several years ago.
Thanks for any advice. Don't worry about embarassing me, I am way past that!
