More new shop questions
Rick Snyder
>Posted before about my new shop(dust collection). My next question is about heating that shop. (24x24 or 26x24) I'm looking for a good brand,type,and price.
Thanks, Rick
Re: More new shop questions
Re: More new shop questions *LINK*
Ron Hildreth, Alta, Iowa
>Rick,
You can do a Google search, and look at about any type of heating alternatives you can imagine. A good place to start might be Harbor Frieght at the link below;
Ron in Iowa
Harbor Freight
Larry Clinton
>Rick, if you have the space above your ceiling you may want to think about a conventional home type hot air furnace with Central air. These can be purchased in a "horizontal" and direct venting configuration that would allow it to lay on the ceiling joists (or bottom of the trusses). Obviously you would have to have access and clearance around the furnace / CA cabinet. This style is very efficient (my furnace is 97 percent / Air seer 10 or 12) and pretty trouble free. I had the trusses designed for my shop so that I ended up with a 10' wide 8' high room full length of my 30 X 30 shop. I installed the furnace at the end of the upstairs room - ran a trunk between the ceiling joists of the trusses toward the outsides of the shop (it did cause me to drop an area of the 10' first floor ceiling about 4"). then I ran 2 trunks parallel to the outside walls about 4' from the wall. I used insulated flex heat duct to install 3 registers on each of these walls & 1 register in the upstairs area. I then filled the area over the piping and trunk with blow in insulation. I have a cold air return on the shop ceiling. This system has proven to hold the temperature - both summer and winter - at a constant temperature throughout the shop. I super-insulated the shop, installed 5 thermopane windows, One 36" insulated entry door and an insulated 8'X 9' overhead door. My heating and cooling costs have been very low (located in central Indiana) and I keep the shop between 55 and 75 year around, holding it at about 72 when I am in the shop.
