Inca 570 Planer/Jointer
Tim Williams
>When jointing, I'm finding that the wood is being flattened into a wedge shape - - i.e. its getting flat, but more of one edge is removed than the other - i.e. if I start with a 2 X 4 board and flatten it, after a few passes, one edge (side) is 1 3/4 and the other is 1 7/8? I think something has moved on me. I know I probably need to ship somehting - - but i don't really understand the geometry
Re: Inca 570 Planer/Jointer
Ray Binnicker
>Hey Tim,
A jointer is designed to flatten a board along its entire length. It is difficult, if not impossible, to apply the necessary downward pressure with the hands/and/or push block across the width of the board to make it equally thick. My goal with the jointer is to make one face and one side flat (not equally thick) and 90 degrees to each other. The planner will then make that face and side the same thickness. I hope I said this right. It sounds right to me. Help me guys. (:-)
Ray Binnicker
Larry Clinton
>If the bottom of the board is flat your doing what your supposed too do, that is flatten the surface - period. A jointer works off of one (1) reference surface. That is the surface on the bed of the jointer. Its function is to remove all high spots and "flatten" that surface - this has no connection or relationship with the second side. You can somewhat influence what is removed, IE: If you put all your pressure on one edge it will probably remove more on that edge. If the board is warped and it requires removing a 1/4" from one edge to flatten, it may only remove 1/8 from the other edge. The only thing that could cause the jointer to remove more from one edge is if the knives are not parallel with the surface of the table. That is fairly easy to measure with a straight edge or dial indicator. In all likely hood, however you don't have a machine problem. I usually remove about 1/32 to 1/16" per pass - Maybe your removing too much material. The previous poster was correct in that you use the planer to flatten one surface, and then one edge - by feeding the first joined surface against the fence. This gives you a flat side and a straight edge at 90 degree to the flat side. You can then plane the second surface parallel to the first (to the thickness desired) and either saw the second edge or if it is a thick (like a 4 X 4 or 4 x 6) plane the second edge parallel. The Planer does not function to "flatten" a board - only to make the second surface parallel to the "jointed" or flat surface. If you surface plane a bowed board - you will just get a thinner bowed board.
Ray Binnicker
>That was what I meant to say. (:-)
Ray Binnicker
wilbur
>Hi Tim,
I also have a combo jointer planer machine, although it's not an Inca (drool). Here are some techniques that I find helpful.
1. Check your knives to make sure that they are in line with your outfeed table, and that the infeed and outfeed tables are coplanar. It might be that the knives in the cutterhead are higher on one end compared to the other, or that there's a discrepancy between the infeed and outfeed table that's causing the jointer to take a bigger cut on one side of the board compared to the other.
2. Cut your pieces down close to rough size before jointing and planing. I made a table out of 2x material a little while ago, and instead of jointing an entire 2x4 before cutting the leg pieces out of it, I cut the 2x4 down close to the lengths I needed and then jointed and planed them to final dimensions.
3. Use the jointer to get your stock just "flat enough", and then switch over to planer mode to thickness the stock to the dimension that you want. I've had good success using the jointer mode to get my stock close to flat, meaning getting most of the high spots knocked down, switching to planer mode to get the opposite side parallel to the jointed side, and finally alternating sides in the planer to get to final dimension. (Hope that made sense -- it's much easier to demonstrate this procedure than describe it.)
Arthur Allen
>I have the Inca 570. The tables of all jointers need to be in the same plane and the outfeed table needs to be the same height as the knives. The Inca 570 does not have any adjustment knobs to bring the two tables into the same plane. The adjustment knobs at the end of each table raise and lower the tables. To bring the tables into the same plane, start by unplugging the machine and remove the fence and guard so that you can access all the screws that hold the tables in place. To adjust the infeed and/or outfeed tables, loosen the screws enough to allow you to place shims under the front and/or back of each side of each table. After placing your shims, tighten the screws on the table. Place a straight-edge on one side of the outfeed table that will hang over the infeed table about 18" Measure the height of the straight-edge over the infeed table near the knives and near the end of the straight-edge. If the tables are not parallel, then you know that shims will need to be added/deducted. In order to be coplanar, the tables need to be parallel on both the fence side and the operator�s side and the height of the outfeed table over the infeed table needs to be consistent across from the fence side to the operator�s side. I find that it takes a lot of trial and error to get good results. Standard Allen wrenches are awkward to use because of the obstructions that are in place. I recommend buying some T-handle Allen wrenches which makes the job a lot easier. I find that raising and lowering the tables by using the adjustment knobs tends to be bring the tables out of adjustment. Therefore, I do not raise or lower the tables. Even with practice, it can easily take an hour to get the tables properly adjusted. Fortunately, the tables will retain their settings for a long time.
The designers intended that when using the machine as a planer, the user will remove the outfeed table so that the dust collection hood can be used and the user will have easier access when feeding in stock. I found that this is time consuming and tended to get the tables out of adjustment so I did not remove the outfeed table when using the planer (I no longer use the planer function). I built a dust collection box that fit over the jointer head, and it was very effective.
