Coated deck screws - Color?
Dan Manturi
>I am ready to put the boards on my deck in progress. I would use stainless screws except I may be converting this room to a florida room and the screws will be covered and perhaps removed. So I am going with coated screws and looking at square drive instead of phillips. Would love to use nails but I thin screws are better.
Anyway, coated screws come in green, gray, beige... I am using pressure treated and the green may be best, but was wondering if they would end up looking funny when the deck weathers or if they fade as well. I will not be staining the deck, but will just coat it every couple of years until I enclose it. I cannot seem to find plain old galvanized with square drive. Phillips can be a pain after a long day.
Anyone have experience with these coated screws?
Thanks.
Re: Coated deck screws - Color?
Ray Binnicker
>Dan,
I think, I may be wrong, the "new" pressure treated lumber does not recommend the galvanized screws. The stuff they preserve the lumber with now days causes the galvanized screws to deterioate. You don't think you may cover the deck boards with another flooring if you convert it to a Florida room? I used the tan color with my new deck. They don't seem to stand out too much.
Ray Binnicker
>Dan,
The ACQ treated lumber requires ceramic or stainless fasteners; it will eat galvanized by dinner next Thursday. While screws hold better and give you the option of easy removal, you might want to consider checker-head stainless ring-shank nails.
mm
Dan Manturi
>If I go Florida Room, I'd likely remove the 5/4 and replace it with 3/4" plywood. Going over it would make a pretty thick floor with respect to the level of the house floor. That is why I want to go with square drive screws. They strip a heck of a lot less than phillips going in and coming out.
Dan
Keith Newton
>Mark, I bought a battery powered Skill brand colated drivers at HD for about $150 a few years ago. At that price, it will pay for itself in time saved on just a job or two. The screws are not much higher than the same number bought in the smaller box size either.
Also, because of the greater holding capicity, of the screws, I have started just using one screw per joist crossing, and skip from one side of the deck board to the other on every other joist, thinking that if I got any edge curling up, I could always go back and add a few more screws later. So far, that has not been needed.
Re: Scewed
>Your choice, of course Keith, but I think you're asking for curl with that system. We use 2/per joist, each predrilled & countersunk and set to an even depth; that way the weathering stress on the board is even.
If you're going with visable fasteners, I also think it looks better that way.
mm
Bill Hammond, Oregon Coast
>Dan,
The deck should be lower than the interior flooring so that water will not run into the house under the door when it rains. Typically 1 1/2 lower, this also allows for flashing under the door. When the Florida room comes along adding 3/4 it will still be lower, and you would have room to add firing strips to level the floor and bring it flush. Decks typically have a slope to them to make the water run off.
If you do decide to remove the the decking you may be interested it star drive screws. They are easier to remove than the sq or phillips head screws. SS ring shank nails will require a chainsaw to remove the decking. DAMHIKT
Bill
