Delta Rockwell Drill Press
Jarred Edgecombe
>Hey Guys:
I am teaching shop at a small high school in rural Wisconsin. It has an old Rockwell Radial Drill press. The problem with the press is that the tip of the drill bits wobble approx. 1/16" Can someone point me to a place that has more information on these old drill presses? Or are there any experts out there who can give me advise?
Re: Delta Rockwell Drill Press
wilbur
>Check out the Old Woodworking Machines website.
owwm.com is full of information.
owwm.org is a forum where you'll be able to get a lot of help with your problem.
Al Stokka - Cambridge, Iowa
>Jarred,
Just a guess in the case of your Rockwell but, most drill presses use a Morse tapered shank on the chuck to hold it in the spindle. The first and most likely cause of a wobbling bit is that tapered shank, paricularly in a school. The Morse taper may be damaged by a nick, a burr, or rust. Lower the spindle and look for an oblong hole in the spindle. If there is such a hole you will see the upper end of the tapered shank. A wedge driven into the oblong hole will force the chuck/shank out of the spindle so have a helper hold onto the chuck while you drive the wedge, so the chuck doesn't hit the floor or, more important, your foot. Examine the tapered shank for the above mentioned nicks, burrs, or rust. If found smooth them away with a fine stone, clean both the taper and the inside of the spindle and reinstall the chuck. Do so by opening the chunk to it's maximum (this will retract the jaws into the chuck body and keep the safe from damage), positioning the tatpered shank into the spindle, positioning a block of wood under the chuck, and rapping the wood block smartly with a hammer. One or two blows should secure the shank in the spindle.
Al
Jarred Edgecombe
>thanks for the help, I will check it out Monday.
Jarred Edgecombe
>I'll take a look, thanks.
>I agree with Al. If you don't have the slot he mentioned, you may have to remove the chuck from the taper that goes into the top of the chuck (No. 33 taper?) The way to do this is to drive two opposing wedges in between the top of the chuck and a shoulder on the shaft. The wedges look like tuning forks without handles, sort of. I did not know such things existed and reinvented them. In my case, I used two wrenches and drove one in from each side. It's been a long time, so I have forgotten some of the details, or maybe I am blocking them out. I made it happen, but ignorance is a bad place to start. It would have been ten times easier with the proper wedges.
Maybe someone will jump in and tell us their proper name and where to get them. Where is Forrest Addy when you need him?
Would an automotive tie rod pickle fork work?
Ron Hildreth, Alta, Iowa
Re: Wedges & drill drift
>Barry,
I was hoping to avoid the "wedges" subject! Why? Because then I'd have to look them up for other's reference since, if one hasn't seen them, they're tough to visualize. Now you went and forced my hand. ;^)
Anywho, they are called (by MSC Industrial Supply Co.; www.mscdirect.com; 800-645-7270) "drill chuck removal wedges". Novel idea to call them that, huh? On the MSC website search for item 08592941 - that's the item number for a set of wedges for a 3JT (#3 Jacobs taper). It is a set of two small-taper wedges that are driven between the chuck body and the spindle end from opposing sides of the spindle.
By the way, the jam-it-in-the-spindle-slot-to-remove-the-Morse-taper thingie is called a "drill drift" and is MSC item 0007021 (for a #2 Morse taper).
Al
Re: Don't think so
>Ron,
Good thought but, I think the pickle fork tips are too thick to fit two of them into the small gap between the chuck and spindle. Even if they will fit I think the taper is too steep to enable driving them toward each other to release the tapered shank.
I guess it would be worth a try if one has the forks at hand, though.
Al
