Two 220V machines on one circuit?
wilbur
>I have a 1.5 HP dust collector that I posted about last week. The motor is rated to draw 16 amps at 120V, and 8 amps at 220 V. It trips the 120V 20A circuit that it sits on pretty regularly on startup. After doing some troubleshooting, I'm considering converting the motor to run on 220V instead.
The main problem is that when I wired my shop, I made provisions for a single 220V 20A circuit and outlet. A jointer planer combo machine with a 2 HP, 220V / 8.9 amp motor is plugged into this circuit.
I think I'll just install a second 220V circuit for the dust collector, but I was wondering if anyone would run two 220V machines on a single circuit. If I connect a second 220V outlet to this circuit, with a total constant current draw of 17 amps between the two machines, I think that this would be too close to the 20A capacity of this circuit for comfort.
Am I right on this point? Does anyone have two 220V machines on a single circuit?
