RIKON, 10-345
Roger
>I am looking for input, good, bad or indifferent on the RIKON 10-35 Bandsaw. I am considering replacing my Delta 14" with Riser Kit and the RIKON 18" seems to have a lot going for it considering the price.
TIA Roger
RIKON, 10-345
Roger
TIA Roger
Re: RIKON, 10-345
>I've got one. It has performed reasonably well so far. The fence is a little bit light. I'd prefer a heavier one. The table is nice and heavy and massive. I like having the two speeds. It has worked nicely with the factory blade, but that is going to go away soon and will probably be replace with a Woodslicer or Timberwolf.
Re: RIKON, 10-345
arw01
>I bought this unit June of 06 and set it up just a few months ago (yeah really).
Other than some rust on the corner of the table where the protective plastic had drooped away, the saw was in great shape.
I think I am missing one handle for the tension wheel, but I can grasp it to tighten up the blade.
The stock blade wasn't too bad, but I replaced it with a woodslicer I had bought a couple weeks after putting the saw on layaway. This blade would not tension so I had a bit taken off at a local shop. They told me they took maybe 3/8's out, and it was fine from there. I ordered a second woodslicer because that was not tensioning, but I've not taken it out of the box.
The saw has plenty of power, I've resawn to about 10" so far. Mostly I work in the 6 to 8" width currently.
The fence will not skew for drift, but I find my drift to be really small and have been ignoring it. But I DID find the fence to NOT be square to the table the other day, and need to deal with that. Creates a tapered resaw when the pieces get taller that presents some challenges getting thick enough stock.
Also the fence is not stiff enough, as it flexes at the back with moderate pressure.
Additionally the top wheel mounting on mine was not tight in the channel they put it in, I shimmed mine with some post it notes to lock it in place a little better.
When you figure you will have to spend some more money on the fence, another machine may be a better purchase.
Bottom line, there isn't another machine in it's class at $999.
Alan
Re: RIKON, 10-345
Roger
>Alan and JL;
Thanks for the information, it will be very helpful in making my decision.
Roger
