The right dado set?
The right dado set?
The right dado set?
Mark Kozlowski
>I recently acquired a "slightly used" Dimar dado set from Lee Valley at a good discount. When I got it home I realized it was a set optimized for melamine. The two side-cutting blades each have 46 teeth. I have a 1.5 horsepower contractor's saw (Rigid TS 3650) and plan to use the dado set primarily in plywood and mdf. Would I be better off with a more standard set with side-cutting blades that have 24 teeth? Will the 46 tooth blades put too much stress on my 1.5 horsepower motor?
Re: The right dado set?
Rob Stokes in North Vancouver
>Try it, listen to your motor. You'll know right away.
Rob
Don Evans
>There is no rule that says you must do it full depth with one cut that I know of:
Take shallower cuts if necessary.
Don
Slower feed rate, too
Ron Hildreth, Alta, Iowa
