sticky windows
sticky windows
sticky windows
Ernie Miller
>I'm doing a flip house and there are some older doubble hung windows that don't work very well should be replaced but not in the budger. any way is there a way to make them slide easier? way to many coats of paint. any ideas? I thought about WD40 or even possable vegitable spray though I would consult before doing somthing stupid
Re: sticky windows
Re: sticky windows
John Veerkamp
>Ernie,
Silicon spray will work well to make them slide. The only drawback is that before the next painting, the silicon will need to be removed.
John
Re: sticky windows
Re: sticky windows
Lee Ohmart
>My experience with older houses and sticky windows is that the issue is the paint. If it was latex based paint, it does not slide and tends to gall. Multiple layers of oil bases paint can also bind things up. In my first house, I disassembled the old windows, which were all but painted shut, sanded off several layers of paint, probably full of lead, and put on a layer of a good hard drying enamel. Before I put them back together, I let the paint dry nice and hard. Then I rubbed on some parrafin wax. Slicked them up nice and it didn't cost much in materials, just time.
Re: sticky windows
Re: sticky windows
Al Stokka - Cambridge, Iowa
>Ernie,
If the windows aren't too bad, rubbing pariffin wax (like your momma used for sealing jelly jars) at all the places that the sash contacts the stops and jambs will make them slide easier. If that doesn't work, sanding the contact areas and coating with paraffin might do the trick without causing you to repaint.
Al
Re: sticky windows
Re: sticky windows
Hank Knight
>Two of my previous homes had old casement windows with counterweights. They had been long since painted closed. I took the frames apart, removed the paint with paint remover, replaced the weight ropes with nylon ones, reworked the weather seals, reassembled the windows and repainted them They looked like a Million Bucks and worked like new. It took some work, but it was not difficult and it was well worth the effort.
Re: sticky windows
How to un- sticky windows
Lee Schierer - McKean, PA
>You can also rub down the contact areas around the frame with steel wool and paste wax. The steel wool will remove the roughness and the wax wil aid in making it slide. Don't use beeswax as it tends to be a bit too sticky for this application. An old candle will do the trick as well.
Re: sticky windows
Re: sticky windows
Ken Oakley- Sunny St. Cloud, Fla
>The real old timers would just rub a bar of hand soap on the sash or frame. I know because that was one of my jobs when I was a boy and had to change the storm windows for the screens in the spring.
Re: sticky windows
My Old House
>Hello Ernie and Hank,
My last home was a circa 1890 three story 8 bedroom stone house with chestnut trim and windows, which were double hung. Some of them(bathroom and stairwell)employed stained glass. No way I was going to do anything short of complete restoration. They were covered with decades worth of enamel paint. It took a million years, but the result was spectacular. Chestnut is a PITA to work with, though.
George
Re: sticky windows
Bart Goldberg
Don't use vegetabe oil - It will turn rancid!
Bart Goldberg
Re: sticky windows
Re: sticky windows
>I would be leery of liquid sprays such as WD 40 and Silicon. I'm pretty sure silicon works for a few minutes and then the paints softens and it makes it worse. Try wax, soap or talc.
