Anyone else here have one of those days,
Eddie Pacheco, San Jose, Ca.
>Where you have a 73 3/4" tall door opening and, because of mental door threshold and door seal consideration, you make a perfect 70" door? What the H was I thinking?
Got side tracked on my shed completion and decided to test hang the door before I add a glass or wood panel insert to the top opening. I can't believe what a numbskull I was on this one....It's a fixable problem, but DAAANG!
Oh, on the shorter than norm door opening. Both Nancy and I have plenty of vertical clearance.
Re: Anyone else here have one of those days,
Forgot to mention,
>The door is made from a rough redwood 12 x 12 that a buddy gave me so I made do with the knots. I'm going to paint it when I get done which will now serve two purposes. Weather protection and screwup concealment.
Shish...
Charles
>Reminds me of some bookshelves I made for my wife's craft room. I made through dadoes where there should have been stopped dadoes and drilled too many shelf-pin holes on one side. It was my first project after about a year and a half off. I made her swear to say that she got it at a yard sale if anyone asked.
Dale Lenz
Re: Your looking at it all wrong, Eddie...
Dale Lenz
>Time to make a negetive a positive. One way is to lower the door and use to top space for those window thingys over the door, hummmm.... transom,yea, that what there called, : ' >. Thanks for showing us your human side.
Stuart Hough
>Eddie, you were just having a Buddhist moment! You really want all the little critters to know they are welcome in your home! ....snicker..snicker
GerryinSurrey formerly Agassiz previously Halfmoon
>Jeez, Eddie, I don't know what all the angst is about, the door fits just fine side to side. And, how tall is norm?
Gerry
Yeah, my front screen door has
CJ McLaughlin (MPLS)
>a 1" strip added to its top and a 2" strip added to its bottom. That was a fun day.
CJ
vince
>I don`t know what anyone else would do but I would cut that jamb down and put on some real wide custom trim.Then I would keep the wood look.
Thanx, Dale. That's a good idea,
Eddie Pacheco: San Jose, Ca.
>I will lower the jamb and door assembly. If I glue a piece along the bottom I'll have expansion contraction problems on that joint.
Thanks Stuart....Ha,ha
>We live up against a hill and we already have our fair share of critters. Earlier this summer our dog got bit by a rattlesnake that was in our backyard. Our dog is still alive, but it was several $$$$ in Vet bills. Last month I killed a rattler (5 rattles) that was in our front yard. I'll be sealing the base perimiter of the shed with wire mesh.
Don't you know,
>That any day Ian Kirby, Ellis Wallentine, Chico Sakman, Sam Maloof and any other of the top dogs may vist my house...:-) Yeah, it'll never happen, but 3 3/4" IS a glaring mistake. I was proud that the casing and door fit was right on except for the height.
The normal door height, I belive, is 80". The shed is situated under the eve of the house so i couldn't make it too tall.
That was the other consideration.
>I'll lower the door and put a shelf or ledge piece across the top. Like you, I would like to leave the door natural with a spar varnish or light stain to block the UV, but this area gets a lot of sunshine as the sun travels across our backyard. The 12 x 12 was one of 4 from a pergola that my buddy removed from a house he had just purchased and he was wondering what to do with them. I'm glad I stopped by. Twelve by twelve select redwood doesn't come by cheaply anymore.
Ken Oakley-Sunny St. Cloud, Fla.
>Why not just leave it as is. In a short while one of those famous Calif. earthquakes or mudslides will happen and chances are good that will rearrange the opening for you
I'd make it a Dutch door.....
Kneale Brownson in sunny N. MI
>...and take up the slack with "supports" for the little shelf.
Ace Foster in Port Orchard
>The word to the wise that's superfluous:
before you move the repair to the top of the door, think about where the lockset will end up.
Ace
Bill Schreiber, Litchfield, NH
>Eddie,
I feel your pain. I own several of those t-shirts.
Regards,
Bill Schreiber
Always Short
Nick Tuzzolino
>It's amazing how a person almost ALWAYS cuts something too short. I can't recall ever cutting anything too long, to be remedied easily. Nice door, though.
Larry Clinton
>I think I would put a filler block on the bottom then install one of the stainless steel or brass "kick plates" on both sides. Then you could consider it a design improvement!
We know the real truth
DB
>The gap is just a pet door for the pet python that you are going to get.
Re: Thanks Stuart....Ha,ha
Stuart Hough
>Now that IS a scary though! I would use "hardware cloth" with nothing larger than a 1/4" mesh to be safe! Ya gotta keep out those pygmies too! When we moved into the last house we owned in Florida it was a regular occurence to open the front door and find a Pygmy Rattler on the concrete front porch, just sittin' there sunnin' itself! Like it still owned the property. Needless to say, I DON'T have Buddhist moments anymore!
