Veritas - Innovation in Tools
hydrolics
hydrolics
hydrolics
Ronald
>hope someone can help me! got a 3-point hitch on a small tractor and the hydrolics will either go all the way up or down. no control. i think i have a pinched o-ring. and getting blow by. the question is how do i relieve the pressure so i can find the problem?
Re: hydrolics
Re: hydrolics
Basil
>They're so many different makes and models out there these days all I can suggest is get a manual for that particular tractor and go to the 3-point hitch controls section.
Otherwise, if it has draft control, that's where I'd look first for a sticking valve.
Re: hydrolics
Re: hydrolics
Dale Stansbery
>You didn't say what kind of tractor you have but that's normal operation for the old Ford 9/2n's in the 40's.
Re: hydrolics
Re: hydrolics
Larry Marker in Alabama
>I had a John Deere 650 utility tractor that was pretty much like that. It was impossibnle to control the 3-pt hitch to use a blade or landscaping box with any precision. It would do more than all-the-way-up or all-the-way-down, but it was not very good at precision settings in between.
It turns out, that was a consequence of the el cheapo design and there was nothing the dealer could do to adjust it.
Larry
Re: hydrolics
Re: hydrolics
Pete in Holland, MI
>Look up "yesterdays tractor" on line. There are discussion forums there with the right people to talk with.
Re: hydrolics
Re: hydrolics
Ronald
>this did work great but all at once it started acting up. it is a New Holland. sorry i should have said that. there has got to be something to stop the pressure to the control valve. we just got to find out where or how. thanks for all the help.
