ADVERTISE HERE - FREE TRIAL
Coating inside shop vac?
Gary Smyth
>I need to recoat the inside if a metal shop vac. I'd like something smooth and water resistant. Also because of the abrasive shop stuff, something reasonably hard. I don't have a lot to spend on the inside of a shop vac so powder coating or the like is out. What about simple polyurethane? Engine enamel? Any suggestions?
Re: Coating inside shop vac?
Rob Stokes in North Vancouver
>Tooth up the surface with some 80 grit and use an epoxy?
Donno - never done that before. I'd be a bit concerned about the coefficient of thermal expansion differences between the metal and the coating though (whatever coating you choose). If you use a rigid coating (like epoxy) and it moves differently than the metal when heated/cooled, the mechanical bond will be stressed - possibly to the point of failure. BUT - if the epoxy was re-enforced you'd end up with a tub inside a tub so mechanical adhesion wouldn't be required.
Perhaps a spar varnish? It's a lot more flexible than a polyurethane. Not sure how it would adhere to the metal though.
Just thoughts.
Rob
Isn't it chrome?
>Isn't the inside chrome? Mine is inside and outside. I thoguht they were all like that.
If it is, or it it's already coated someway, I'm not sure alot of things will stick.
If it's bare metal, I don't think I'd spend more than $3 on a small can of RustoLeum and a brush.
Happy Woodworking!
Gil Jones on Lake Seminole GA
>Check a good auto parts store for a spray-can of that stuff they spray in a pickup truck bed as a resilient liner (Rino Liner??). That is if it is sold in DIY spray cans. My shop-vac collection drum is plastic.
How about truck bed lining.
Ray Thompson - Middletown,IN
Just a giant steel can
Gary Smyth
Lee Ohmart
>The toughest stuff I have found that comes out of a spray can is urethane based paint. I used it on my support posts in the cellar over Rustoleum primer and has stood up well to two children who used the space as a play area. I also used it on the baseboard heat in the mud room. The only place it has chipped is under the key hanger where family members have dropped their keys when they miss the hook. Other than that, the baseboard has not chipped from kicked off soccer spikes, dropped firewood and other insults. Watch out when spraying it however that you protect surrounding objects. The spray creates a mist in the air that sticks to any object it encounters leaving tiny flects of paint that is very difficult to remove.
