Walnut ladle
Walnut ladle
Walnut ladle
Mik eSchwing from Maryland
>This is a tall black walnut ladle, maybe 18" tall. No finish, just sanded to a high grit. Very thin ladle, about 1/8" or less for most of it. The long slender handle is actually rather stout. For display only of course in some rich lady's kitchen probably. It will probably get mounted on a wall hanging display stand of some sort yet to be determined. Comments welcomed.
Re: Walnut ladle
Re: Outstanding as usual!
Darrin
>I think I'll just call it a night!
Darrin
Re: Walnut ladle
Re: Walnut ladle
Keith Newton
>Mike, Nice work. I have a new gallery opening coming up soon, and need some smaller faster objects. Seeing these has given me some inspirations.
Re: Walnut ladle
Re: Walnut ladle
Martin from Granbury
>Mike,
It looks really delicate. How did you make it? All hand tools?
What about the "cup"? Did you rough it out with forstner bits?
I have never tried anything like this, but your work is impressive.
Martin
Re: Walnut ladle
Re: Walnut ladle
Mike Schwing from Md.
>Thank you Martin, Keith, Darrin
Martin, no forstner bits. For the hollowing I use a Foredom flex shaft with a 1/4" shaft carbide ball just like the one pictured below. I wrote a complete start to finish article on these spoons a few years ago for Woodcraft mag, you could find the article I'm sure if desired. Most of the entire spoon is crafted with that same bit, but I use others, too. Those carbide bits cut impressively well but they have to be used carefully as they are very finicky about grain orientation, as opposed to the other common types of carving bits. I do a lot of the handle with a drawknife, files and rasps of various sorts. Hope that helps some.
Re: Walnut ladle
forgot pic
>Sorry. Here is the bit I use mostly on the interior of the spoon.
