Need hope chest help
Pat Evans
>Below is a crude isometric of a hope chest I am attempting to design. It will be a 42" L x 18" W x 18" H raised panel chest with cedar lining. I haven't selected wood yet, but I envision a darker frame and top with a lighter panel. All corners will be rounded over with a 1" radius. Convention might put feet on it, but I dislike places for dust to collect and am going for a more contemporary look. The one thing that has me stumped right now is how to incorporate handles into the end panels. I want to make wooden handles rather than adding on factory made handles.
Any suggestions on handles or any other aspect of the chest would be most welcome.
Re: Need hope chest help
Jesper, Denmark
Jesper, Denmark
>Pat, It is really not all that big, so does it need handles?
I am using a routed wood shape handle on most of my shop drawers etc. It is basically a 1" by 1�" with 1/4 roundovers on the two outside corners and a cove on the underside. I make this in a long length and cut it with 45� corners to fit the particular use. You could attach it all the way out on the frame for strength.
Glenn Madsen near San Francisco
>I never put handles on mine. They almost never get moved.
Have fun with the project. These are almost always very well received, even when they aren't absolutely perfect.
Moving a hope chest
Lee Schierer - McKean, PA
>My wifes hope chest has stayed in the same place for over 20 years. It does have wheels under it for moving it for cleaning purposes. The bottom of the wheels stick about 1/4" below the bottom of the base. When it sits on carpet they are invisible, but it still rolls pretty easily.
Lee
Dick Coers
>I would not use raised panels for a contemporary look. Maybe something more like a "pillow" raised panel. That would have a short flat to go in the groove, then a convex shaped radius going up to the full thickness of the panel. I always like to add something to the base of the chest to add visual weight. It may not have to me a molding, but a wider board, or thicker board will help. Since we often look at furniture like that standing up, we are looking at the wood at a pretty severe angle and the bottom boards appear thinner.
Dan Mitchell
>Pat - I have 3 different pdf's of hope chest plans I can email you for inspiration if you like. One of them from Wood magazine is very contemporary & especially nice, to my eye.
Dan
