Paint Removal with Hand Planer
Jobn Pierce
>Can I use a hand planer (power tool version) to remove old paint from lumber?
John
Jobn Pierce
John
Re: Paint Removal with Hand Planer
Larry Clinton
>It will dull the blades quite rapidly. Normally the paint has fillers / pigment that are pretty abrasive. If I were going to use the planer, I would use old blades or have a new set ready to put in when through. The citrus type paint remover usually works well for me, I apply the remover, let it set for the time required then remove the paint. I have used a stiff brush and a water hose (in my gravel driveway) to remove finish from old furniture. I can usually get 99.9% of the finish off in that manner, removing the rest with a scraper.
>Larry is right, Paint will dull he blades quicker than most wood, but you can do it.
You did not say what kid of paint or how old. Be careful it does not contain lead. Wear a proper respirator so that you do not inhale the dust. I am not a lead paint Nazi, but this could be a severe exposure.
Grant in Iowa
>Jobn,
You can use either your portable planer, or a regular power planer.
Yes, the paint will dull the knives, but this technique will limit or nearly eliminate the duling effect:
-Make sure you take some wood with the paint, if even a small amount. This will allow the planer knives to hit the wood first, and come up beneath the paint. This prevents the paint from making much contact at all with the knives. So take a good deep cut and you shouldn't have any trouble. This will also limit the amount of paint that is impacted by the knives, thereby reducing any particulate creation and thus airborne particles.
I am assuming the lumber isn't part of a house, or whatever, and that there are no nails or screws buried in it of course.
FWIW,
Grant in Iowa
Don Pierson
>If you don't have a lot of paint to remove you can use a hot air blower. I have a 1500 watt blower that when on high blows air at 1100 degrees F. The heat softens the old paint and I scrape it off with a putty knife. The same method is used to soften and remove putty from old windows. This removes the bulk of the paint and then you can use paint remover, sander, etc.
John Pierce
>My Question was quite brief. I should have given more detail. The paint in on the ceiling side of my Front porch. It is about 20' by 5' in size and has an original (50yrs) old coat of oil base paint followed by a coat or two of latex. I power washed it and am searching for ways of getting a smooth surface to repaint. The surface is now about 30% bare wood, 10% oil base and 60% oil and Latex. There are no areas where the latex would not support a hand planer. The exact overlapping cuts of a planer would not even be obvious to a person, who never looks up to see what the under side is. I just cannot stand to think of the hours of scraping which would be required. I should mention that the base wood is plywood. I did not think of the nail heads that must be there.
One of the respondents suggested chemical striping, but the upside down nature of this project doesn't seem too good for that approach.
John
DB
>The easiest way would be to just put new sheets of plywood over the existing plywood and paint that. Then you will not have to dispose of the lead based paint that you remove.
If the old paint is thick enough you can get a chisel edge putty knife (about 1-1/2" wide) from a good hardware store and start scraping away. If it comes off with ease then it will not take too long to finish. If the paint does not come off easily then use a heat gun, and the putty knife.
Re: Paint Removal with Hand Planer *LINK*
Mark Harrison - Brisbane, Australia
>I had a Metabo paint stripper machine (see link below) that I used to remove a lot of paint. It will easily do what you want. The paint will come off in chips and it can be connected to a vacuum cleaner to collect the chips. See if you can rent one if this is a one off job.
If this is a big job then this is the right tool for the job.
Metabo Paint Stripper
Jobn Pierce
Re: If it were mine I would probably use a
Larry Clinton
>disk sander (yeah, electric drill type disk, not ROS) with a coarse grit 40 ~ 60 and knock off any loose paint, then feather the edges. That is provided the existing paint is adhered well - apparently it is as you are thinking of scrapping it off with a plane. Then I might use a somewhat finer disk or ROS if the feathering looked to rough. Then I would apply a good coat of Zinser oil based primer, and paint of your choice. I would expect you could do all the sanding & feathering in an hour or so and be done with it.
