>OK. Got a rail and stile set from Price Choopper.com and figure I do some doors. The panel profile worked just fine, but when it comes time to cut the rail ends, I haven't figured a way to feed the piece so that the bit doesn't take a deeper chunk at the start of the cut until the bearing makes contact. Those here who use these router bits care to share the details on how to do this??
>When coping the ends you do not need a bearing. What you need is a split fence on the router table, with as small of an opening as possible and a miter gauge set at exactly 90 degrees. The miter gauge will need to have some way to securly hold the piece in place. Set the outfeed fence exactly even with the shallowest cut of the router bit. Set the infeed fence a little deeper than the outfeed fence. Cut your stock to the exact length needed plus twice the difference of the two fences.
Example: If the infeed fence is 1/16" deeper than the outfeed fence then cut your stock 1/8" longer than needed.
One last thing run a piece of scrap through the coping setup and use this as a backer to prevent blow out. You did run the profile first didn't you?
I could of had it all set up faster than it took to type all of this up.
>Woodworking magazine for a nice illustrated article on this subject with pretty colored pictures and everything...shows some nice shopmade jigs and tips too.
>I have a shaper and have not done this on my router table, but I think it is about the same.
I tried cutting the using the miter gauge as a "carrier" and that would work fine if I could get the fence exactly parallel to the miter slot, but that was too much trouble. What I ended up with was a scrape block that was fairly large or at least wide, maybe six or eight by twelve. I put that behind the piece and use it to keep the rail square to the fence and from moving in and out. You could make up a fixture with clamps etc, but for me it works just as well to squeeze it tight to the edge with my fingers and take a light pass and then do it again taking the rest. The pusher block gets the profile cut in the edge, but it serves as the backer to avoid the tear out. I seldom if ever use the guide bearing, but I could.
I sometimes put a piece of slick 1/4 inch plywood over my fence with the fence as far forward as I can and then slide it back with the cutter running so that only the working part of the cutter is exposed. That sometimes requires a clearance or starter hole in the Plywood. This gives you the minimum opening in the fence.
PS, On tearout, Depending on the outside profile of the doors, I sometimes cut the rails and styles a 1/16 or 1/8" too wide and then rip them down to clean up the edges after the profiles are cut. Actually you only need to do this on the rails, but I often do both so that every price is interchangeable until the last minute. If you want to get really crazy you can rip the rails, assemble the doors, square and profile the ends and then rip the edges of the rails to clean them up before profiling the outer edge. Its the end grain cuts that cause the tear out. At the very least, profile the ends first or in a sequence that causes the end to be profiled before the sides.
>Mark I do more or less what Barry suggests. I gave up on the miter gauge because my fence is independant and hard to align with the miter slot. I simply cut a bunch of square blocks and use these to push the work along the fence. Once you mess up the lead edge of the block I rotate it to a new edge or simply toss it.
>In the past, I've just installed the router bit and set the height. Then using a straightedge, set the fence flush with the bearing on the bit. Next, set up my miter gauge with a flat scrap of wood or MDF attached as a backer and make sure it's square to the fence. Set the rail against the miter gauge and hold it firmly while running it past the bit. This worked for me for years.
Last year I bought a coping sled from Eagle America that was on sale and I plan to use it when I get the next opportunity. Not only will it clamp the rail down securely, but it has a backer piece that helps prevent tear-out and a handle to grasp while pushing the work. Something like this might make the job easier, safer, and make the cuts come out better. The prices aren't bad either.
This and the next pic are of my homemade sleds, inspired by the Eagle coping sled. I made a nearly identical set for #3 son who uses them professionally. I added another clamp to his, and I recommend you employ multiple clamps when you choose to buy or make your own. Let the sleds ride along the fence when stiling or coping. You get good control and safe handling.
>Tear-out was not a problem as I used a piece of profiled scrap for a backer. I'll make a couple of clamping sleds and they should do fine so long as I get the lengths cut correctly.
Tried the big block first, but couldn't lock the rail in well enough
>My fence is 1-piece solid, so the "jointer" method won't work for me. I tried the miter guage, but the rail would slip a little and screw up the straight cut.
>Except I don't have a shaper, I use my router table the same way. I just cut a few scrap blocks with perfectly square ends about 8" or longer by 5" or wider. I use a thin straight edge to align the fence with the bearing on the bit. Then I put the 8" side against the fence and grip the stile against the front of the block with the end of the stile against the fence and run the part through, cutting into the guide block a half inch or so. If the stile doesn't touch the bearing on the bit - adjust the fence till it just touches. I flip the block after cutting a couple just to insure the stile is well backed up to prevent tear-out. If you make the block long, you can cut it off to remove the router cuts and continue to use it on different setups. I have a split fence (Benchdog) on my router table and 2 miter gage slots, but this method sets up so fast and works so well I never have tried any other.
>Was the stock clamped to the miter gauge? Could also put some self adhesive sandpaper on the miter gauge. Another way to do it is to start with a wide board, cope the ends, rip to width, then cut the profile.
>Use a fresh piece every time or to cut the pusher block down to expose a fresh edge. I just assumed the part of the block that got cut away wasn't needed because the part that remained was the part that supported the remaining part of the wood. Now that I think about it, It might be a good idea. The fresh edge would support the work while it was being cut and not allow it to flex.
I make a certain number of fixtures and sleds but since I do small batches of things I tend to make pretty simple crude ones and they often get thrown away when the job is over. Perhaps I should rethink that can make more permanent ones.
If the pieces tend to creep against the block, you can use a piece of blue tape. Does a remarkable job. Stronger than you would think.
>I cut the length of the rail for the stile end and leave it as a dimensional piece of lumber (ie: uncut 12 by.
Then after cutting the stile in each end, I cut the final rail thickness I want it to be. Then run all 4 rails at the same time to give me the finish edge on all the rails. I must admit now though, after reading the posts here that the sled would save some time and some scrap wood laying around.
