scratch in table
scratch in table
scratch in table
Gary
>My hall table has a new scratch in it! Grrrrr. Oh well, the price of having kids around....well worth it.
Anyway, what is the best way to fix it? The table is made of Cherry, with a finish of BLO, shellac, and many coats of wipe-on poly.
Thanks,
Gary
Re: scratch in table
close-up of blemish
Gary
Re: close-up of blemish
Stuart Johnson
>I would try rubbing it out with tooth paste prior to refinishing.
Mark McC
>After trying to repair the two or three dings and dents on my hall table I learned it was more effective to simply cover them up by strategically locating the mail and newspaper.
Parents and tables have one thing in common when it comes to Kids...Advanced Aging!
Rob Stokes in North Vancouver
>I'd leave it. The wood fibers are broken, meaning much end grain is exposed. As such, any addition of any clear finish, wax or stain is going to absorb and the scratch will tun from white to a dark colour.
If it's really bothering you, a wax stick is your best bet. But I build furniture to be used, not to be looked at and for me, a scratch on work I've done is a badge of success.
Rob
Dick Coers
>Wait till the kids move out. By then it won't bother you because there will be a lot more scratches. Besides, one of them will get the table one day and that scratch can bother them!!
Charles Wiggins
>Gary,
I delivered furniture for 2 1/2 years, and you can imagine all the awful things that can happen in shipping and moving.
If I were in your shoes I would get a variety of wax sticks and touch-up markers in the color range you have represented. Most people just melt the wax into the gouge, but it rarely matches very well. If you get a good match right out of the package, faint immediately.
I work and warm the wax with my fingers and take different colors and blend them until I have a good match for the dominant color, THEN I melt it in with a 'woodburning' iron. Let it build up so it's proud of the surface. Let it cool so it's good and firm, then scrape it down flush. I sometimes sand it GENTLY with fine paper (220-320 over a wood block), which can be a little scary, but it actually helps in the blending out.
Use the markers to recreate the grain. Take your time and keep a rag handy. If you mess up you can usually wipe it off if you do it quickly. If you get one area looking good, go do something else for a while and let it dry well so you don't wipe off the good with the bad.
Once you have to look down, seal it with spray poly. Use a light touch and build up several THIN coats, feathering out toward the edge more and more with each coat. Once you have it sealed, you might want to go back over it with the wipe on poly to even things out.
I once used this method to repair a 4 inch long, 1/4 inch deep gouge in a dark cherry dresser in 30 minutes, sitting in the back of the delivery truck. (A bed frame had fallen against it at our previous stop.) I had the wax, markers, spray, a lighter, and a pocket knife. When we delivered the dresser, the new owner ran her hand right over the repair and never knew it.
All in all though, with the kids around, you may just want to cover it with a doily and wait 'til the kids move out.
Little putty, little paint....
>The ironclad way to do it is to put some water-soluble filler in the scratch to bring it flush with the surrounding wood, then lightly sand with very fine paper and grain-paint the patch to match the surrounding wood. Use a tiny red sable brush and a bottle-cap of lacquer or shellac, dip the brush in the shellac and then into powdered pigment(s) to create the exact color you want, then just paint it in. Use a contrasting color to match growth rings and other features. Let it dry, then pad on some more top coat.
It's Hollywood, but it's permanent and if you do it well, nobody will be the wiser.
