New Jointer FINALLY setup,.. almost
Brian in Brighton
>Well, after sitting in a box for 2 months, the Grizzly G0490 is finally setup. I removed the cutterhead to change to the Shelix head, found a few shims that worry me. I can't get the bearings off the orginal shaft as the press fit is too much. I will see if I get to use the neighbors press to help them out. I will check the elevation with a dial indicator on the new shelix head to make it parallel to the beds at install. I had not thought about that before. With a standard cutterhead the blade can be tweeked to be straight and parallel. The Shelix head can only be shimmed.
So has anyone else seen this problem?
Brian in Brighton
