Re: cabinet building books
Jim Dillon
>Matt,
Several books that were helpful to me prior to building our kitchen cabinets were:
Danny Proulx, "Building Your Own Kitchen Cabinets", Popular Woodworking Books;
Paul Levine, "Making Kitchen Cabinets: A Foolproof System... ", Taunton Press; and
Jim Tolpin, "Building Traditional Kitchen Cabinets", Taunton Press.
Each has a different focus and are complimentary to one another. Proulx's and Tolpin's books focus more on traditional cabinets whereas Levin's book describes the European style. Having said that, Proulx uses a unique hybrid construction that combines the efficiency ans space saving techniques of European construction with the traditional face-frame approach. I used his approach and like it. Levin's book also has a nice section on using and working with countertop laminate.
Regarding sizing, traditional sizing is based on the most efficient use of a 4 x 8 sheet of plywood, the height of kitchen appliances, and the thickness of the normal kitchen countertop. This means that the bottom cabinet will be roughly 24 inches wide and 32 inches tall (give or take) and top units will be 12 inches wide (give or take) by whatever height you like or your ceiling dictates. But this is not cast in stone. For example, because my wife and I are tall, I made one bank of cabinets 38 inches (total) tall and the other bank 40 inches tall. And for the upper cabinets I think I made them an inch wider than normal to accommodate larger dishes. Keep in mind that if you do depart from the "traditional" sizes, you will also have to elevate your appliances. Hope this helps.
With your experience, you should have no problem.
Jim
