Way OT Problem with my elbow questions?
>I did some work on a house for a friend that involved crawling around under it and repairing rot. I installed new joists next to old ones and "tails" on some that were just damaged on ends.
Apparently I hurt my elsod. My right elbow is swollen and puffy around the "point". It may be slightly red, but it does not appear to be a bruise, at least it is not purple. It is slightly sensitive, but not painful. Feels sort of squishy when I rest it on the arm rest of a chair. Its been about a week.
What I am wondering is, Is this serious or do I just wait it out? I thought it was going away, but it returned. Would an Ace bandage help?
Re: Way OT Problem with my elbow questions?
John E in SC
>Sounds like olecranon bursitis. It's not usually serious unless it's infected (which would be red, warm, and tender). You should see your doctor to be sure. Usual treatment is aspirating the fluid, and possibly injecting steroids into the bursa. Most likely this is a result of crawling around on your elbows. Ace bandage might be helpful once the fluid is aspirated, but probably wouldn't do much before that. Bottom line - see your doctor.
John
Usual disclaimer - this medical advice is worth exactly what you paid for it. Your results may vary, etc. etc.
Sean Troy
>At this point, a heating pad a few times a day would help. I would also use some ibuprofen to lesson the swelling. A doctors visit sure wouldn't hurt, you never know about joints.
Mark Kauder, Phenix City, AL
>Barry,
I had just this same thing about 4-5 years ago. It was a delayed result of slipping on the grass on a hill in my yard, and landing on my elbows. I remember it was my right elbow, it was just as you described.
I do not remember all the treatment details, though I did go to the doctor, and I do remember that there was not injections or aspiration of the fluid with a needle (I would remember that). I do remember wearing an elastic, slip on bandage.
Go see your doctor.
Mark
John Veerkamp
>Basic steps may help. Ibuprophen to reduce inflamation, once or twice a day alternating warm soaking with cold pack 15 minutes each. If it is not significantly better in a few days of this then see your doctor.
John
steve - Denver
>I would suggest ice as opposed to heat. Heat causes blood to flow to the affected area, increasing the inflamation. Sounds worth a trip to the Dr, just to make sure it's nothing serious and that you won't do more damage to it by using it.
Dan Donaldson
>I would keep an eye on it, especially if the puffiness gets any larger. I had something like that a few years ago and it kept getting bigger. Started from a tiny nick on my elbow and spread down my arm over a period of a few days. I finally went to the doctor and it was a subcutaneous infection that took some IV's and other stuff to get rid of. I agree with the others, if it does not go away soon, go see your doctor.
Frank House
>Too late to help you this time but -- since breaking my left elbow years ago, I have taken to wearing kneepads on my elbows as well as my knees when crawling joists. I found some that are adaptable for small knees.
Wearing pads has the additional advantage that badly inserted nails left by the builder are less of a danger.
Cyclists' elbow protectors are not as useful.
Best wishes for a speedy recovery,
Frank.
Randy Johnson Connersville, IN
>I learned the hard way that any wound in or near a joint is to be taken VERY seriously.
I had a puncture in one of my knees that I ignored for several days. Then I had a painful night, an early morning visit to the emergency room, and a four day stay in the hospital complete with round the clock IVs and a small surgical procedure. (As an aside, after the surgery I knew why people get hooked on drugs. I don't know what they gave me, but I felt GOOD.)It was explained to me that the fluid surrounding a joint acts almost like a growth culture. As soon as bacteria gets in it grows much more rapidly than it would in, say, a small cut on your arm.
A few years ago when I got a good case of road rash on my elbow from an unplanned bicycle stop I was able to recognise the symptoms early and escape with some oral antibiotics.
Jim Dillon
>Barry,
Given the environment where you might have got a scratch or something, I wouldn't delay too much longer in seeing a doctor. While it might be nothing, an infection is nothing to mess around with. I almost lost a foot when I was young from a simple toe blister that got infected. Of course I ignored it until the discoloration started up my leg and got to knee level. Got a big lecture from the doctor and a lot of antibiotics to take. So keep an eye on it. I now understand why plumbers wear knee pads when working under a house on sewer pipes. Good luck.
Jim (usual disclaimer - I'm not an MD etc., etc.)
