Finish Problem
Finish Problem
Finish Problem
Doug Reynolds in Seattle
>What's going on with my finish? I got some red oak baseboard early last spring and put it up in my garage for the summer until last week. Stained with Daly's oil based English Oak. Waited a few days until the "bleeding" stopped then applied oil based poly by brush. Waited at least 24 hours then sprayed on oil based poly. First coat looked good but, second can dried as if it had sand in it. Granted I did it late in the afternoon and I think there was some blushing there next morning. I stripped the clear finish off with two applications of a citris stripper. Even after drying, my sandpaper clogged. Now the baseboard is "bleeding" as if the original stain was not dry. Granted if I need 24 hours or more at 70 degrees plus for a finish to dry, there may be a week or two in the middle of July that meets those conditions here in Seattle, but, this makes me think that something else is going on. What is it?
Re: Finish Problem
Re: Finish Problem
eliot d
>Sounds like a question for Michael Dresner(sp?).
Re: Finish Problem
It's quite possible
Michael Dresdner
>It's quite possible that the original stain was not dry, and in any case, finishing in this area this week is going to be a big challenge unless you are already heating the shop. It's been raining every day, and the humidity in many shops is quite high.
I see you fighting two challenges. One is the wood, and the other is the weather.
While low temperatures slow finish cure, high humidity can be even more disastrous. Oil based coatings and stains often contain driers to speed up their cure. Adding drier to raw linseed oil, for instance, can move it from taking eight days to cure to only one. Unfortunately, high humidity can disable the drier making the finish, or in this case, the stain, dry as if it were raw oil. To make matters worse, the particular mechanism that driers employ is that they shuttle oxygen into the finish to help it polymerize. Stain trapped in the deep pores of oak need that even more, so disabled driers will be even more problematic.
The bottom line is that you may very well be having drying problems both with the stain and the top coat.
As for the pebbly second coat, that may have more to do with temperature, since cool temperatures affect flow out, especially with aerosol applications.
As I said in my email, if you need more, feel free to call as I gather you are right here in the Seattle area, making you a local. We PNW types need to stick together.
Re: Finish Problem
Re: Finish Problem
eliot d
>Told you Dresdner is the man! ( Sorry about the spelling.)
