>I have a Rigid 16 gallon shop vac that, with the noise muffler installed, is every bit as quiet as the Fein Turbo II (probably having to do with the 2" hose compared to the Fein). I hook it up to my radial arm saw when I cut pen blanks to size, and at my drill press when I drill the blanks. The problem is that the filter clogs very quickly. As an example, the suction indicator pegged out today, indicating a suction drop. I opened the tank and found the filter packed full, but only about 1 gallon of chips in the tank. I took out the filter, knocked out the packed dust and reinstalled the filter. With a clean filter, it will suck the paint off of metal.
There are "finer" filters available, but I would assume this would not eliminate the clogging with dust.
HD has bags to fit this vac, but they run about $7 each, which could quickly become expensive. I don't know if I could reuse one, not knowing if I could empty it without destroying it.
I have thought about wrapping the filter with a foam sleeve, but I don't know if this would really accomplish anything.
So, I'm wondering if anyone has a suggestion as to keeping the filter from clogging so quickly, or an idea of cheaper bags that might fit?
>I have found that the Shop-Vac bags fit my Ridgid. They are substantially less expensive than the Ridgid bags and are even available on eBay with further discounts.
>I have an ancient Sears shop vac (32 gal. or whatever the big ones were) and it has a pleated filter. The problem is that there is nothing inside the pleats to keep them "fluffed" up or separated. Therefore, they collapse or suck themselves flat, sort of eliminating any advantage of the pleating. The pleating was supposed to dramatically increase the surface area. I tried to take it apart and figure out some way to insert combs or foam or something to hold them apart, but the whole thing is glued together and I don't want to chance pulling it apart.
I have the same problem you do. If I use it to suck up "fines" such as sanding dust it clogs quickly. I have opened it to find that the filter was a big ball of sawdust and there was almost nothing in the drum. I take it out and beat it against the side of my big "roll to the curb" trashcan. I turn it around and whack it over and over until it is clean. Don't know of an answer.
This happens to dust collectors also. The advantage of the pleated drum filters for them is largely negated by the fines packing up in the pleats. The internal brushes they install in them do little good because they don't knock the dust out of the "valleys" in the pleats. So the first time you turn them on the dust collector is amazing. After you pack them with dust, not so much. My DC has a bag on it and the same thing happens. The bag gets a layer of
"cake" on them. That Makes it finer and it filters out more of the fine material, but it also reduces air flow. I took the bag off mine and turned it inside out and shook it out. It was stunning what a difference it made.
Have you seen or considered the cyclone drum Onieda has for vaccum cleaners. It's called "Dust Deputy". Sounds like it would be great for your problem. I cannot remember their web site address but last I looked you could get it complete for $150.00 and without the drum for $100.00. You use one of those 5 gallon dry wall mud buckets and make the top out of plywood if you go the latter route.
With cost of filter bags wouldn't take long to pay for it in your case sounds like.
I've got Onieda cyclone collector so don't use vaccum except for floor and short on room only reason I don't have one.
>If your filter is the pleated canister shaped type, you can take a large women's nylon stocking and pull it over the thing. Cut it to length first. It will eventually clog too, but is much easier to clean (or just throw it away)
The cyclone units drop the big chips out before they get to the VAC. They are more useful for planers and things that created lots of shavings. Dust will still go straight through a cyclonic separator and clog the vacuum filter.
I do like pecker, and use a section of pantyhose over my filter. The larger shavings bounce off and fall into the drum. Only the small dust particles make it through to the filter. After 7-10 hours of use I have to take the whole thing apart and clean the dust out of the pleats.
now who here is going to admit to having a large woman to steal a stocking from?
I got a nylon bag from one of the BORGs that just fits over my rigid pleated filter, often I can just shake the vac to make the dust fall down. Other times I'll open and brush the dust off into the canister or garbage can. When I am done for the day (all right, when I need the vac again and it's all clogged up) I will open and dump the canister and use the air hose to blow off the bag and then the filter from the inside. If possible I do this on days the wind is blowing towards the yard with the barking dogs.
The Nylon bag is a fine mesh and will trap drywall dust, may have been sold for that purpose.
>I have an the big ShopVac (yeah its noisy) but both the original pleated filter and the high performance micro filter require the foam sleeve. It does have a lot of power, but I can suck up about 15 gal or so of shavings / dust before cleaning. I blow the cartridge and foam clean (outside my shop) with an air hose, then wash the foam sleeve when necessary using dish soap (in SHMBO'S kitchen sink). Seems to work well for me.
>I got a Rigid from the Borg several years ago. Whenever the thing started to bog down, I take out the filter and go outside and gently whack it with a small stick to unclog it. Preferably on days that the wind is blowing towards the neighbor that complains about my barking dogs. When I notice that it clogs up quickly, I replace the filter. So far thats been about once a year.
>Thanks, Don. I have a central dc system ready to run piping to. The shop vac is used now for catching the little bit of stuff from my drill press and ras, but mainly for sweeping up around the mini-lathe, sanding dust, etc. The filter clogs way before the tank is even 1/4 full.
>Don, I misunderstood your original post. I looked at the Oneida site. You may be on to something; every magazine that tested the Dust Deputy had nothing but good things to say.
