TS won't start with stacked dado
Dan Mitchell
>Recently got a Powermatic PM2000 table saw. Today I installed the full set (all chippers & spacers) of a new Freud 208 stacked dado, in order to cut through a blade insert I had made for the dado. Slowly elevating the blade, the saw easily cut through the insert & the 3/4" pine board I had clamped across the table to hold the insert down. So far so good. Admiring my new insert, I decided to lower the blade to a height of about 1/4" and makes some practice cuts through some 2x4 scrap (this is my 1st experience with a dado). However when I pushed the on button, the saw would simply spin up for a second or 2, then shut down. Pushing the start button immediately produced no response at all. Only after sitting about a minute would the saw even attempt to power up, producing the same result; a brief, seemingly 1/2 speed spin up, then a shut down. It did this about 5 times. I opened the cover, the motor & all seemed fine, motor was quiet cool to the touch (about 55 in the shop right now. I pulled the dado (which took several minutes as the blades fit quite tightly on the arbor) and re-installed my WWII combo blade, and the saw started & ran fine. I have not yet tried the dado again (surprised what a PITA it is to install these, especially the full set) but I thought I post here in case anyone has any ideas about the events so far. In the manual troubleshooting section under "Motor starts slowly or fails to come up to speed", the causes listed are low voltage (line measures 237 volts, drops to about 232 for a ~half second on startup, then goes back to 237. Remains at 237 during a cut), bad motor & centrifugal switch, which I gather is located in the motor. Of these cause, the centrifugal switch seems the most likely. Maybe the additional mass of the dado slow startup slightly & the centrifugal switch cuts the power, perhaps because it's overly sensitive? Who knows. Again, if anyone has any ideas I'd like to hear them.
TIA
Dan
Re: TS won't start with stacked dado
Jerry Nicholson
>My thought would be either bad start switch or bad start capacitor. If it were mine, I would check the start capacitor first.
Jerry
Dan Mitchell
>Thanks for the reply. I reinstalled the complete dado set, though minus the spacers. The saw started perfectly & I was able to cut a number of practice grooves in the aforementioned 2x4. Weird. Again I have to wonder if the additional mass of the spacers I omitted this time was enough to somehow vex the centrifugal switch, or some other aspect of the start setup.
If there's one thing I hate, it's an intermittent problem ;-)
Dan
R. Lance in GR, Michigan
>Dan....I'm not familiar with the start/stop switch on your saw, but I made a paddle that I added to my switch for safety to turn my saw off by bumping with a knee....and I've experienced not having my saw start at times because of being clumsy and making slight contact with that paddle when I try to start the saw...the saw is being told to start and stop at the same time and will not start...sometimes new saws have a big safety shut off built on the switch and I thought maybe this was a possibility for you.
Dan Mitchell
>Thanks for the reply. The saw does have a large red outer ring which forms the shutoff button, but it's not being touched. I reinstalled the shim set that came with the dado, & again the saw will not start. I can only conclude it must be that the added mass is preventing the blade from coming up to speed fast enough to satisfy the centrifugal switch that takes the motor from start to run mode. I opened the switch/contactor box & observed the goings-on. The saw attempts to start, runs slower than full speed, produces a sort of rattling sound inside the cabinet, and the overload trips on the switch assembly. Looks like a call to Powermatic is in order.
Dan
Dave's Not Here
>I wonder if the problem might be with your throat plate. Try lowering the blade all the way down before turning the saw on. It's possible that the insert has closed up just a tad and is pinching the blade.
If the saw starts with the blade lowered, raise the blade up through the insert again and it should widen out the insert enough so that it will fix your problem.
I Agree Dan
>With your last comment that it is time to call Powermatic. I can't imagine the miniscule mass of the dado shim preventing a start cycle. Let us know what you find out. This is a wierd case.
George
Dan Mitchell
>Dave - Thanks for the reply. Good thought, but the last test with spacers where it didn't start were made with the blade all the way down & the insert removed.
Dan
John Veerkamp
>One other possibility, with the shims in place and the blade all the way down, some part of the dado assembly is touching something under the table, possibly the trunions.
John
Stuart Hough
>When experiencing the problem, was the dado stack set in the full up position, and was the insert in place? Also, what was the actual width of the dado stack (with shims)? It is possible that the stack is wider than the saw is designed for, and is rubbing on something or that your insert is too thick, and the arbor washer and/or nut are binding against the insert. I know it sounds a bit too simple, but it always seems to be the "little" things that get by us.
Dan Mitchell
>Thanks for the replies. Nope, not a clearance issue. Dado w/shims is 7/8". It's set the way Freud says for a 7/8" dado. Again what's weird is I set it up the 1st time, lowered it all the way, then put in the new insert I made & clamped a board over top. Dado cut through the insert & board, all the way up, no problem. Shut off the saw, removed the board & insert & cranked the blade down to do a test cut of ~ 1/4" depth. Saw wouldn't start. Removed the shims, saw ran, put them back, didn't run. WEIRD! I'm going to try it one more time tonight, then call PM in the morning if it does the same.
Thanks again for the suggestions.
Dan
SOLVED!
Dan Mitchell
>Or so it seems at least. Although I had checked this when the saw arrived, and although I have been using the saw for a couple weeks now as it was delivered, the apparent problem was a slightly loose belt. I observed the start up attempts with the side cover open, & noted some shuddering of the belt. Tightening it slightly (about 3/32" movement of the lower motor pivot point in the "tighter" direction) has seemed to eliminate the problem. Saw now starts fine w/the entire dado pack. Belts do stretch a bit on initial use, so maybe that's what happened here.
Thank you once again to all who replied.
Dan
Re: I've got a Freud 208 Dado set.
Glenn Madsen near San Francisco
>The total mass of the spacers can't be half a gram. I doubt that's your problem.
This is a new saw. Call Powermatic. Let them earn some of the customer service money they collected.
Re: SOLVED!
Charles M
>Dan,
Glad that you may have it solved. I was leaning toward the problem being some other power hog on the same circuit that was running at the same time. Low voltage will cause the exact problem you were having. I've heard of people that scratched their heads over intermittent start problems until finding that their wives happened to be using the dryer, dishwasher, etc. at those mysterious times.
Re: SOLVED!
Jim Dillon
>Dan,
Hope you found the real problem. Otherwise, I agree with Glenn on this. You have a new top-of-the-line, expensive TS and your problem shouldn't happen. I know it is great to try to figure things out, but if tightening the belt(s) doesn't work, I would get on the phone with your dealer, PM directly, or both. FWIW, it is hard for me to believe that a slightly loose belt would prevent the saw from starting. But, hey, if it runs, you did good!
Jim
Re: SOLVED!
Dan Mitchell
>Thanks for the replies. The saw is on its own 220 line, I actually measured it steady-state, while the saw starts, while it's cutting, etc, stays between 232 (very briefly at startup) and 237. I agree, seems a little drastic for a loose belt. PM has an email tech support option. Since the saw SEEMS to be OK & it's not urgent, I may email them the problem & see what they say.
Dan
