Re: Joint-a-bili-t not straight
Dick Coers
>Their sales pitch from the beginning was that this was a matched set edge trimming tool. They always said that the tube did not need to be straight for it to work. If you trim one board on side a, and the other board on side b, both boards may have a slight bow. One board concave, the other convex. That bow should match and the boards join together. Are you cutting this way? I will have to look and see if I can figure out where the screws are. If you want to straighten it out you will have to set some blocks at the ends of the beam and use a clamp pulling against something heavier like a workbench top. Then bring in a new base and screw it to the beam while clamped straight. Add more screws so it will not creep back, or slightly overbend the steel for springback.
