A55 Smoothing Plane
Fein Turbo II
Fein Turbo II
Fein Turbo II
Mike Farinella
>Anyone have one? I want to install a dust bag but can't figure out if I need to buy a filter.
Re: Fein Turbo II
Jim DeLaney, Austintown, Ohio
Re: Fein Turbo II
>I don't use a filter when I use the bags.
BTW, the Shopvac 12 gallon bags will fit the Fein, and they're a lot cheaper - and more readily available.
Also, the CleanStream� (GoreTex�) filter intended for the older Sears vac will fit the Fein, too, and it's less than half the cost of the Fein filter.
Jim D.
Re: Fein Turbo II
Thanks Jim
Mike Farinella
>and thanks for telling me about the Shop Vac equivalents (I just ordered 6 Fein bags from Amazon for $32!).
Re: Fein Turbo II
Bags & filter
Curt Harms
>I don't know if it's right or wrong, but I use both the bags & filter. The Fein bags fit around the outside of the vac. The filter will fit inside the bag. Jim is correct, the 12 gal. bags fit fine.
Curt
Re: Fein Turbo II
outside of the vac?
Mike Farinella
>please explain.
Re: Fein Turbo II
Re: outside of the vac?
John McGaw
>I have a Turbo III which I believe is roughly the same mechanically as the smaller ones. The HEPA filter clamps into the middle of the blower assembly. The bag fits via a rubber gasket to a snorkel which protrudes into the tank from the side at the hose location. The bag for the Turbo III is quite long and remains semi-folded at the bottom but the bag does not interfere with the filter at all. I use both all the time. When I'm vacuuming up really fine material such as drywall dust quite a bit gets through and clogs the filter but the filter can simply be pulled out and knocked once or twice and most of the caked dust falls off. When use for real woodworking applications the dust is not nearly so fine and the bag catches most of it leaving the filter relatively clean.
Re: Fein Turbo II
Re: Fein Turbo II
Phil Thien
>I would think you'd want to use the filter WITH the bag. Otherwise, if the bag breaks, dirt could enter the motor quite easily.
Re: Fein Turbo II
Re: Fein Turbo II
Kris Lasure
>If you want to really step up in dust collection with your Fein, go with a Dust Deputy from Oneida. I was really skeptical at first about spending the money for this thing, but after several months of sanding and miter box use, I have yet to empty the vacuum or clean the filter. I use a Clean Stream filter on my Fein and it seemed I was always cleaning the filter after using the orbital sander for an extended amount of time. Once I hooked up the DD I have yet to clean the filter and all that fine sanding dust sits in the bottom of DD drum. I use this for my miter box and my sanders.
I'm in no way affiliated with Oneida, just a satisfied customer.
kl
Re: Fein Turbo II
Same withth e Turbo II
Hank Knight
>I use the same set-up with my Turbo II: Filter in the center with the bag wrapped around it. Works fine. The filter almost never needs cleaning.
BTW, I've found that when I need to empty the bag, I can cut slit in the botom, empty it, fold the bottom back over the slit and glue it down with Elmers, Tightbond, whatever's handy, and reuse the bag. Works as good as a new bag. I actually fold it over twice and clamp the fold between two sticks until the glue dries. Sometimes I add a little packing tape to the fix to reinforce. it. I haven't bought a bag for my Turbo II in two years.
Hank
