REAL MILK PAINT
Drying thick Walnut Planks?
Paul in NJ
>I have some 4/4, 5/4, 8/4 and 12/4 walnut that has been drying outside for a year. The 4/4 and 5/4 is down to 11.5-12 percent according to my moisture meter and I have moved that into my shop for use later this year. I doubt the thick planks are that dry on the inside. Should I leave the 8/4 and 12/4 outside for another year or two? Do you think they would dry quicker inside the shop? I keep a little heat in the shop all winter and run a dehumidifer during the warm humid weather. I also keep a small fan running all the time to keep the air circulating.
Thanks,
Paul Dzioba
Re: Drying thick Walnut Planks?
Re: Drying thick Walnut Planks? *LINK*
JohnKJordan in East TN
>Paul,
Many people dry wood that way - air dry outside for a while then bring inside to finish, stickered, of course. The moisture will be much lower inside a conditioned space so lumber will dry quicker and reach equilibrium at a lower MC. One rule-of-thumb for air drying is "one year per inch of thickness", to which some people add "plus one year".
If you want get an accurate read on the moisture content (MC) inside your lumber, the best method is to cut a narrow crossection a bit from the one board (one inch wide, 12" or so from the end), weigh carefully, dry in an oven until the weight no longer changes, then weigh again to get the oven-dry weight. Use the formula %MC = 100 x (wet weight - oven-dry weight) / oven-dry weight. This link has instructions: http://www.woodweb.com/knowledge_base/Water_and_Wood.html
There are several webboards devoted to processing and drying wood. The one in the link below is very good - you can search the messages, search the knowledge base, or ask your question there and usually get expert advice. It is run by Gene Wengert, a recognized expert in the field. Another good forum is the Forestry Forum but it had a breakdown recently and lost the archives.
Woodweb Sawing and Drying forum
Dale Lenz
Dale Lenz
>I've been dinkin with drying wood for close to 20 years now. If it was me I'd bring the thicker wood inside and sticker as mentioned earlier. In my shop, my AD wood will normally dry below 10% in 2~4 weeks.
Dale Lenz
Re: Edit: Inch material that is
Dale Lenz
move it inside if you wish
Bill Tindall, E.TN
>Walnut dries easily and it is had to screw it up. You won't dry it too fast under the inside conditions you describe.
Hard to say how dry the 12/4 is. The inch rule is valueless for predicting as it will depend on humidity, temperature, air movement and even the characteristics of the log. Here in TN lumber dries much faster than the "inch rule" would predict so long as there is good air circulation.
The lumber won't dry much outside once it gets cold and damp. On the other hand inside space may be short and you may only want to move inside what you need to use in the next year.
Me Too Dale.Bring it inside.
Barbara Gill, Remlik VA
