rusted pool light conduit
Joseph Mulherin
>I am going to replace the pool light. Found out that the conduit leading from connection box above ground to light is rusted thru and is probably plugged with dirt...cannot push thru the fish tape to connect the new cable and pull the cable up so I can reconnect it and use the new light.
I tried probing in the water(chilly) with a probe and found out that the plug is about 40" inside the conduit. and is underground about 3 1/2ft. Thought of cutting the concrete decking but saw is short and only cut 3"...have about another 1/2 to 2" left to cut thru. Thought about trying to blow air down the upper part and possibly clear out the dirt and not have to dig it up.... Previous cable has been already pulled out, so I cannot use it to connect the new cable and pull it thru. Suggestion PLEASE.....
