Confusion stacking up with new dado blade
Dan Mitchell
>Just got a Freud 208 stacked dado set. Never used one before. I'm a bit confused about how to place the blades on the arbor. I understand about the carbide facing forward. The (very brief, image-less) instructions say "If chippers are to be used, place them on with the teeth of the chippers in the gullet of the outside blade. The gullet? Huh? The outside blades have the carbide face. About .5" behind the carbide face (as the blade rotates) is a non-tipped prong. Then there's a gap of about 1.5" until the next carbide face. Each end of the chippers is also 2-pronged, one carbide one not, with a gap of about 1 3/8" between the prongs. Should the 2 prongs of a chipper straddle the carbide & prong tip of the outside blade, or should the 2 prongs of a chipper go in the ~1.5" between outside blade points? It seems like the former, but a couple PICTURES would have been worth a mint here.
Next, it says If more than one chipper is used, rotate every other chipper 90 degrees. OK, so chipper 2 goes on 90 degrees from chipper one, like a + sign. Now where does chipper 3 go, right on top of chipper 1 (i.e., 90 degrees from chipper 2)? The carbides touch if you do that. Seems like you'd want them spaced out evenly around the outer blade. Again, a picture would have been great. If anyone can explain this in words, or if you have some pictures (couldn't find any online using blades like the Freud's) I'd appreciate it.
TIA
Dan
