Unisaw startup jolt, continued...
Rich Glisson, Durham NC
>I wanted to mention a possible solution to the cabinet saw "bang on startup" problem experienced by Tim Jones and others. I remember when this issue caused profound Internet angst several years ago, and I believe there was a solution that was not mentioned in the thread below. That is to loosen the belts slightly so that they can slip a wee bit on startup. It's worth a try.
Re: Unisaw startup jolt, continued...
Ken Oakley-Sunny St. Cloud, Fla.
>But what happens when you are ripping a piece of white oak 3" thick and half way thru the cut and the blade is hot and starting to bind and the belts start to slip. As someone start earlier-Learn to live with it. It is no big deal.
>I dunno. Maybe it would be time turn the saw off and figure out what you're doing wrong?
Pete in Holland, MI
>Seems this is a large 3 phase motor. They do start up quite violently. When I changed my 1.5 hp JET contractors saw from 110 to 220v, it did start up more violently than in the past. This willbe a fact of life with higher power motors with virtually nothing to put a load on them (like on a table saw) during the start up.
Suggest removing the belts from your motor and turn it on & off several times (waiting for the motor to completely stop in between) to see if it is the motor itself. My guess is that the motor, which usually uses gravity to tighten the belts, has a tendency to climb up the belt when it first starts turning, taking up any backlash in the system. Have someone else start/stop the motor while you stare at the motor/belt system looking for movement. If nothing is noticed, start breaking down the drive system at each possible point of movement looking for any back lash. If there is none, then the bang is probably always going to be there, unless you put a soft-start motor starter on your motor.
Pete
>The saws in question are cabinet saws and all have single-phase 3hp motors with mechanical belt tension adjustment. They don't have gravity-powered belt tensioning like a contractor's saw.
Tim Jones
>The belt tension definitely plays into this, but I believe you need to adjust the belts for optimum cutting performance rather than to slip on startup. This means the least amount of belt vibration with reasonable power transfer (no slip). The Delta manual says 1/4" deflection with light finger pressure, the Delta tech I spoke with said to loosen them to about 3/4" deflection. I found the best way to determine the right tension is to actually run the saw while adjusting to get the least amount of belt vibration. You can easily see the belts vibrate and achieve the optimum tension. Obviously, don't get any body parts anywhere close to the pulleys/belts, but it is easy to do safely. With mine, it came to about 3/4" of deflection which matched what the Delta tech said. I am going to persue the capacitor tweaking mentioned in the other thread when I get a chance, but it probably won't be for a month or so. I would think you would need a larger cap to allow the voltage to ramp up slower instead of a smaller or no cap as mentioned in those posts. I'll post my results later, but if anyone has already gone though this process with or without success, I'd like to hear about it...
R. Lance in GR, Michigan
>I think that there is a real possibility that we all may not be experiencing the same thing upon start-up...what one person is referencing as a "bang" or jolt maybe of a different magnitude than what I'm experiencing...also, I've been looking in some old Delta catalogs and find that not all Unisaws come with a magnetic starter/push button starter combination (the magnetic starter apparatus is contained in a box attached to the rear of your saw)...I have this starter feature (a box about 8" x 12") but I don't know if this effects this bang/jolt thing...what I do know is that I'm getting something that might be characterized as a slight jolt...which is somewhat understandable as a 3hp motor is going from dead still to 3450 rpm in a small fraction of a second and some of that energy...the breaking of inertia and all that has to go somewhere...and it is resulting in a jolt...for reference, I happened to tape the last NYW show which was a rerun of the arts and craft mirror Norm makes "for his rear door area with cubbies to place his keys and a shelf to place his mail and hang his coat and check himself out before going out" and there is a great example of a Unisaw undergoing a slight jolt upon startup when he begins to cut out the corbals...and this is a jolt similar to what I get.
>Agreed on idea of belt tensioning for optimum performance, but as I recollect the conclusion was that they can be adjusted so there is momentary slippage when the motor jolts the heck out of the system but no slippage during actual cutting.
