200+ woodworking book reviews
OT, File manager software
Brian in Brighton
>I HATE explorer!! I have XP and was wondering what you guys use for file manager software. I want something that will do exactly what I ask. It will not stop during a copy transfer to ask if I want to copy a particular file type. It will not stop for a file in use and then cancel, but will keep moving and skip that file. It will also be able to overwrite newer files on the backup drive.
I want my XTree!!
The reason: I use a 250Gb backup drive. It's software puts everything in vaults. So to get anything from it you need the factory software on the other computer. I have been looking into backup software and ALL of them make some goofy files that you can't access without the right software. So I want to use a simple copy command. Problems: C:\=50Gb of software, D:\=55Gb of data. Can't ghost as the backup needs to be larger than the source.
So, is there anything out there for XP that is similar to XTree and can do what I want?
CNet is a waste of time in this one, as the "file manager software" gets 19,425 hits in the forums. I don't have time to dig thru more than the first few pages.
Brian in Brighton.
Re: OT, File manager software
Bill Howatt
>Look at something like SyncBack (there is a free version, ViceVersa (spelling) or Google File replication. I use SyncBack scheduled to copy the data folders of one drive to another in the middle of the night, essentially doing an incremental backup, by copying only the changed or new files. You can set rules whether to copy files for varying conditions if necessary.
You might also be able to use XCOPY with the appropriate switches.
Bill
Re: OT, Xtree was great, too bad Norton
Dale Stansbery
>bought it and ruined it
Re: OT, File manager software *LINK*
John McGaw
>I have been using Cobian Backup for automated nightly backups among my networked machines for a couple of years now. It is free and extremely flexible. That extreme flexibility may be a bit of a downside since if you use the most advanced options there is some learning required. But the program is smart enough to actually temporarily make itself an administrator, shut down programs that dislike sharing their data, make its backup, and then restart the programs afterward. It can also backup to multiple destinations, compress data, and divide backups into preset chunks for convenience such as making them writable DVD size.
Black Moon
second syncback & file management
Curt Harms
>I use it to keep file contents the same between a desktop, laptop, and a USB drive.It is manual so You have to remember to use it. I don't like having print and file sharing enabled if I can help it and using syncback, I can avoid it.
For file management & manipulation, Explorer SUCKS!!! Try powerdesk, the standard version works fine, the purchased Pro version has added features like file viewers. The Pro version of Powerdesk also has file synchronization but I found Syncback easier to use.
Syncback-http://www.snapfiles.com/get/SyncBack.html
Powerdesk-http://www.v-com.com/product/PowerDesk_Free_Trial.html
A couple of the more useful utilities I have.
HTH
Curt
Jim Dillon
>Brian,
Can't off any good advice, but your mention of XTREE brought a smile to my face. Boy, that was one VERY useful, super program - especially the DOS versions (XTREE, XTREE GOLD). Then it moved to the Windows platform and it was downhill from then on. Sure miss it! Aahh, those were the days... .
Jim
arw01
>I downloaded it, and will give this a try. Wanted something a little more regular, and with a hosting account at dreamhost, I have a couple hundred GIGS I can back up to for under $10.00 a month with my web page.
Alan
